914.504.319.00, grommet |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
A&PGirl |
Mar 20 2010, 05:14 PM
Senior Member Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
PET 803-05 #33 Qty: 1
note: PET calls it a "grommet" while the parts sticker calls it a "rubber bushing". Purpose: Keeps water from going back down the engine lid cable. ID: 7.33mm Big OD: 11.76mm Small OD: 10.03mm Length of Big OD: 7.29mm Length of the Small OD: 4.11mm Thickness: 1.48mm Total Length: 14.86mm Made of rubber. The rubber seems to be stiffer then other "grommets". |
Lo-Fi Version | Time is now: 9th June 2024 - 01:39 AM |
