914four |
Senior Member ![]() ![]() ![]() Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States ![]() ![]() |
I found all of the threads related to the dash pad removal but I need help removing the dash from the tub. I found four nuts in the front trunk area and the two screws on each side of the dash but cant seem to find any others holding the dash in.
What am I missing? |
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
There is one bolt ( 10mm ) on the bottom that holds the dash to the body,it's hard to miss, the defrost / vent controls also hold the dash in , there is a bolt that attaches that unit to the body in the back , the cables from the unit will hold the dash in .The defrost outlets may be holding , there may be some windshield adhesive that may be holding the front edge to the gasket that goes between the dash and windshield. Take a rubber mallet and tap on the studs in the trunk area to pop the dash lose, there may be a washer still holding onto a stud. Good luck ...
Jack / jaxdream |
Lo-Fi Version | Time is now: 10th June 2024 - 11:03 AM |
