car running bad |
car running bad |
GreatPumpkin |
Mar 24 2010, 07:22 AM
Member Group: Members Posts: 122 Joined: 28-October 07 From: Centerville OHIO Member No.: 8,272 Region Association: None |
it was running fine until i got to school idling high (normal in the morning) then the idle dropped and it started running really bad. i parked and got out to look. there was blue smoke coming out of the exhaust and there was a small puddle of gas where it had seemed to have dripped out of the exhaust. how bad is it? what happened? is it going to blow up in the parking lot? (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/confused24.gif)
GreatPumpkin |
Mar 24 2010, 07:35 AM
help please
TheCabinetmaker |
Mar 24 2010, 07:54 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Hey! Its early. You only waited 12 minutes! Any way, give us a few more specifics please. Fuel injection or carbs? Have you tried to restart it? I doubt it will "blow up" but I guess anythings possible. Have you done anything to the car recently?
dflesburg |
Mar 24 2010, 07:56 AM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
You have a bad plug wire.
I ordered new ones and they will be here tomorrow. |
GreatPumpkin |
Mar 24 2010, 08:01 AM
are you sure thats the problem? is it ok to drive home or not ? its fuel injection. replaced throttle cable
76-914 |
Mar 24 2010, 09:10 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Is the CHT lead still connected? Sounds like it came loose. It is the single blk lead that comes off the #3 cyl and has a single spade connector. Any gas leaking in the engine bay? If not, I doubt you have a fire risk but check carefully.
dflesburg |
Mar 24 2010, 11:48 AM
It should be okay to drive it home if you come straight home. If you want, get a ride home and you and I will go get it when I get home tonight.
GreatPumpkin |
Mar 24 2010, 06:02 PM
where is the cht lead ? any pics of one?
dflesburg |
Mar 25 2010, 04:48 AM
Cylinder Head Temp lead is fine.
I will show it to you when we replace ignition wires. |
dflesburg |
Mar 25 2010, 09:47 AM
If one spark plug isnt firing, 25% of your fuel gets dumped in the exhaust manifold.
GreatPumpkin |
Mar 26 2010, 03:24 PM
not the spark plug wires but where the wire connects to the plug doesnt look right you can wiggle it with your finger and the car runs the same even when this plug isnt connected. does this mean it is a bad spark plug?
GreatPumpkin |
Mar 26 2010, 03:34 PM
it also seems as if the plug wire doesnt fit on the spark plug itself it comes off very easily, like its not even on.
SirAndy |
Mar 26 2010, 03:40 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Sounds like you found it. The wire is threaded into the connector. You can turn the connector clockwise to make a better connection with the wire.
The two need to make a good solid connection, otherwise you won't get good spark on that cylinder ... (IMG:style_emoticons/default/shades.gif) Andy |
GreatPumpkin |
Mar 26 2010, 03:47 PM
its not a very good pic but the inside of this plug is bowl shaped. how does this work.
Attached image(s) |
GreatPumpkin |
Mar 26 2010, 03:49 PM
the spark plug is threaded
Attached image(s) |
SirAndy |
Mar 26 2010, 03:53 PM
its not a very good pic but the inside of this plug is bowl shaped. how does this work. There's supposed to be a small spring clip in the 'bowl'. When pushed onto the sparkplug end, you should be able to feel it snap over the threads ... Like i said above, make sure the wire is tight where it goes into the plug connector. (IMG:style_emoticons/default/shades.gif) Andy |
GreatPumpkin |
Mar 26 2010, 04:09 PM
i dont see why this plug is different from the others. this one plug doesnt have a small spring clip
GreatPumpkin |
Mar 26 2010, 04:18 PM
one plug is sopposed to be different from the others right?
TheCabinetmaker |
Mar 26 2010, 04:20 PM
Katmanken |
Mar 26 2010, 04:22 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Pull another plug wire that seems to be staying in place. Look inside it and you should see the missing clip part. Just don't mix the wires when putting them back on.
Lo-Fi Version | Time is now: 7th June 2024 - 01:18 PM |
