G Man |
Newbie ![]() Group: Members Posts: 20 Joined: 28-February 10 From: Carson City NV Member No.: 11,415 Region Association: None ![]() |
Has anyone looked into swapping in an entire engine trans combo from a FWD car into a 914? Something like Honda, Mitsubishi, VW...I was thinking that you could keep the transverse engine configuration and just transplant the entire drivetrain. The only issue I can think of is that the engine may need to be moved toward the rear of the car so the axles will line up with the hubs. I'm guessing this would require some cutting into the rear trunk area. I searched for this topic and didn't find much. Thanks.
Bruce Hinds |
V-8 madness ![]() ![]() ![]() Group: Members Posts: 748 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest ![]() |
I've often thought this would be an interesting way to go. the problem I see with a transvers mount is the limited distance between the trailing arm mounting positions.
We've got a screaming 2.7 V6 with an autostick in our Seabring that gets 28mpg on the highway going 85. For the automatically inclined, that would be interesting. Then there is the Audi V8! |
GTPatrick |
Member ![]() ![]() Group: Members Posts: 245 Joined: 8-September 05 From: Memphis, Tn. Member No.: 4,768 Region Association: None ![]() |
G-Man , . . .
I had a few years ago brought up the same idea about using say a engine/tranny from a Fiero and transplant it into a 914 . I was thinking about using the Getrag 5 speed tranny used in a fiero since the tranny linkage was already set up for a mid engine use . Using a FWD engine 5 speed manual tranny Getrag/Muncie and putting it into the mid engine position would take a little bit of modification for the linkage/shifting parts . Check out some dude , Rodney Dickman I think , who is big time into Fiero parts and restoration . I think he's out of Illinois or Missoouri (sp?) . Also there may be a problem of width dimensions . But with the people who use a tubular chassis modification for the rear end of 914's , that route may be possible . Also I had planned on using a GM V6 60 degree engine of the 2.8L - 3.4L range . Why I didn't pursue that any further is that I wanted to keep a 914 a original as possible with either a Raby engine or a Porsche 6 cyl engine . Besides , I wanted to keep the GM stuff for maintaing my 2 Fieros anyway . It's possible but it won't be cheap or easy . (IMG:style_emoticons/default/huh.gif) GTP |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,730 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
As always, depends on how much YOU want to put into any conversion. Changing the configuration of a car is a big deal. Lots of downtime, welding, fabbing, things not working......sounds like R&D to me.
I've learned to leave what the factory set up pretty much alone. 914-6 conversions make sense. Fiero caddy conversions make sense etc. Mounting a transverse config in a 914, nah, not for me anyway. You want that, go buy a Fiero, grab a $500 4.9 caddy and do the swap. I did once, thing was a blast, got dam near 30mpg if driven "normal" and wieghed 40lbs less than the iron block V6 did! Plus it was easy to do. (IMG:style_emoticons/default/wink.gif) |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
I think the biggest problem would be shifting the engine assembly to the rear of the car. This is necessary to line up the axles with the hubs. Most FWD cars have the engine and tranny centered over the axles. This would shift the weight to the rear and screw up the weight bias of the 914. It would handle more like a 911. Then there the fact that the engine is in the trunk not the engine bay and the transvers engine looks ugly.
I think a FWD Audi or Subaru would be a better choice. |
Lo-Fi Version | Time is now: 6th July 2025 - 08:07 PM |
