Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
> 900.183.002.02, clutch pedal height adjustment locknut
McMark
post Mar 26 2010, 08:15 PM
914 Freak!
This is the nut that threads onto the upper clutch pedal (914.423.034.00) and tightens against the lower clutch pedal (901.423.312.00) to lock everything in place.
It's made of steel and the original finish is cad plated.
Dimensions:
19mm across the outside flats
5.87mm thick
Thread is 14mm x 1.5
The bottom face of the nut is completely flat, the top face has rounded corners. The flat face should contact the lower clutch pedal (901.423.312.00).
PET Section 702-00, item #41
- Lo-Fi Version Time is now: 11th July 2025 - 06:41 AM
