intake gaskets, which to use? |
raw1298 |
Apr 15 2010, 09:56 PM
Senior Member Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California |
I bought a set of gaskets for my 1.7 and it came with paper intake and a metal crush (aluminum?) gasket. This for the head side of the intake for duel weber 40's. I have the plastic(?) piece that goes between the head and manifold, which side if any uses the crush gasket? I used the search and did not find any info besides the paper.
Cap'n Krusty |
Apr 15 2010, 10:53 PM
The metal gaskets are for a bus with carbs. You'll have to use longer studs if you use the phenolic insulators with your carb manifolds.
The Cap'n |
raw1298 |
Apr 16 2010, 03:37 AM
Already have the longer studs. I guess I will stick to the paper gaskets. Thanks Cap'n.
Lo-Fi Version | Time is now: 9th June 2024 - 09:28 PM |
