> 911 motor mounts, Still use this part?
jeffdon
post Apr 16 2010, 01:39 PM
Do I use this part still with the 911 mounts?
Replies(1 - 7)
dr914@autoatlanta.com
post Apr 16 2010, 01:58 PM
QUOTE(jeffdon @ Apr 16 2010, 12:39 PM) *
yes everything that you took off you reuse.
underthetire
post Apr 16 2010, 01:59 PM
And your probably going to have to slot the mounting holes a little to get them in.
jeffdon
post Apr 16 2010, 02:16 PM
QUOTE(underthetire @ Apr 16 2010, 12:59 PM) *
On the car or on the new mount? Thinking the mount would be better, and way easier.
underthetire
post Apr 16 2010, 02:19 PM
The mount is easier (IMG:style_emoticons/default/biggrin.gif)
Just giving you a heads up so you can get the dremel out.
McMark
post Apr 16 2010, 02:28 PM
914 Freak!
Don't forget the 'cup' and thick washer. Here's everything in order.
jeffdon
post Apr 16 2010, 03:21 PM
QUOTE(McMark @ Apr 16 2010, 01:28 PM) *
Yep, figured on those, but thanks anyhow.
For some reason, my dremel and i are on lousy terms.
Jerry75914
post Apr 16 2010, 06:13 PM
QUOTE(jeffdon @ Apr 16 2010, 02:21 PM) *
I did it with a round metal file and some grimacing. The previous post is dead on, you will need to open up the holes just a bit for them to fit. I did it just last year. Good luck!
- Lo-Fi Version Time is now: 11th July 2025 - 04:48 PM
