thesey914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 ![]() ![]() |
Are these any good for the front -I think they are 964 front or rear callipers (i can't tell which).
Again, I *think* these are 3.5 inch bolt spacing? (IMG:http://www.pelicanparts.com/MotorCity/wmv/used_968_stock(front).jpg) |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
the 964 brakes are the same or virtually the same as 944 turbo IIRC.
thesey914 |
And Turbos are 3.5 bolt spacing. Might be a bit of an over kill but I s'pose they'll look good.
seanery |
my race car has 944t up front with boxster rears. (should be awesome if I ever get to drive it LOL)
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
One of my favorite combo's is the 944T fronts on 24mm Carrera rotors and SC rears on the rear with SC vented rotors and a 19mm MC.
Works well and doesnt cost a fortune. B |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
They're not 3.5" boltspacing though...
The mounting holes need to be modified (only slightly) cheers, Jeroen |
thesey914 |
Jeroen, I measured the bolt spacing and it seemed like 93mm center to center instead of the 89mm (3.5 inches). So one has to open up the holes slightly to mount them...trying to think of a good tool to use for this purpose (IMG:style_emoticons/default/blink.gif) any tips?
seanery |
I don't remember what we used on mine, but if I were gonna do it again, I would use a rotary tool with a carbide tip.
thesey914 |
Seanery, Just viewed your link to Mr clean autodry. Does it work?
seanery |
yes, it works very well! Get the $5 off coupon from their website.
Lo-Fi Version | Time is now: 13th July 2025 - 02:24 PM |
