| wanchaiwarrior |
May 2 2010, 01:48 PM
Newbie ![]() Group: Members Posts: 21 Joined: 16-January 10 From: Los Angeles Member No.: 11,242 Region Association: Southern California |
74 1.8L L-jet was running well before I decided to give the engine a good cleaning and replace all the old vacuum lines. Now it idles great, but as soon as I go beyond 1/10th throttle it just losses all power. At low throttle it will run all the way to 4,000+RPM. But beyond a certain throttle position, regardless of RPM, it just goes limp.
2 months ago I performed a full tune, including valve adjust, pertronix, plugs, rotor, cap. I have triple checked my vacuum hose connections and electrical connections. I even pulled the throttle body off and checked the TPS operation, which appears to be operating properly. Oddly, my throttle body only has one port that goes to the back side of the vacuum advance diaphragm leaving the port on the front of the vacuum advance open. It definitely seems to be related to throttle position. Not sure where to try next. Any suggestions would be greatly appreciated. |
| jsayre914 |
May 2 2010, 02:08 PM
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
the port should not be open to air.
check for a nipple along the goose neck rubber where it connects you should find another port open to the air. you are missing a line. |
| wanchaiwarrior |
May 2 2010, 02:24 PM
I prepared a detailed diagram before I started disassembly and I'm 99% sure there wasn't a vacuum line there before. I found a diagram over at Pelican that showed the extra line running from the opposite side of the throttle body. My throttle body only has one vacuum port.
| messix |
May 2 2010, 03:09 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
I prepared a detailed diagram before I started disassembly and I'm 99% sure there wasn't a vacuum line there before. I found a diagram over at Pelican that showed the extra line running from the opposite side of the throttle body. My throttle body only has one vacuum port. my l=jet doesn't have anything on the advance side either. you good on that. i would check the flapper up at the air box and see if any water got under the cover.could be shorting out the wiper. |
| MrKona |
May 2 2010, 03:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
74 1.8L L-jet was running well before I decided to give the engine a good cleaning and replace all the old vacuum lines. Now it idles great, but as soon as I go beyond 1/10th throttle it just losses all power. At low throttle it will run all the way to 4,000+RPM. But beyond a certain throttle position, regardless of RPM, it just goes limp. 2 months ago I performed a full tune, including valve adjust, pertronix, plugs, rotor, cap. I have triple checked my vacuum hose connections and electrical connections. I even pulled the throttle body off and checked the TPS operation, which appears to be operating properly. Oddly, my throttle body only has one port that goes to the back side of the vacuum advance diaphragm leaving the port on the front of the vacuum advance open. It definitely seems to be related to throttle position. Not sure where to try next. Any suggestions would be greatly appreciated. Are you referring to this port? |
| wanchaiwarrior |
May 2 2010, 03:53 PM
I actually removed the air box before cleaning, so there shouldn't be any water in there.
Now I've tried with the throttle position sensor connected and disconnected and no difference. The car runs great under partial throttle and will rev up just fine. To me, that indicates the air box is correctly measuring air volume and delivering fuel. It is only when I add more than partial throttle that the engine literally stops firing. The second I back off the throttle it goes back to normal. It seems like vacuum, but that would also show up at idle, and it runs absolutely smoothly at idle. |
| wanchaiwarrior |
May 2 2010, 03:57 PM
[/quote] Yes, that one I have. It connects to the port in the rear of the throttle body. The second one that comes out of the other side of the vacuum advance (on the distributor side) is open. |
| computers4kids |
May 2 2010, 04:30 PM
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Did you remember to plug the harness back into the airbox?
| wanchaiwarrior |
May 2 2010, 04:33 PM
| wanchaiwarrior |
May 2 2010, 06:31 PM
I opened up my air flow sensor and discovered the problem. The center tab connection had somehow twisted to the side and was no longer making contact with the center pole. If you look closely you can see the arrow pointing to the copper tang.
Now the car is running like a top!! I'm so happy (IMG:style_emoticons/default/cheer.gif) |
| messix |
May 2 2010, 09:32 PM
thats were i thought you might have had the problem at.
| computers4kids |
May 2 2010, 10:00 PM
Did you remember to plug the harness back into the airbox? Yes. It is connected. I see...connected, but not really. Your symptoms sounded way too familar--I've forgotten to plug that connector in once to often. (IMG:style_emoticons/default/smile.gif) |
| Cap'n Krusty |
May 2 2010, 10:50 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
74 1.8L L-jet was running well before I decided to give the engine a good cleaning and replace all the old vacuum lines. Now it idles great, but as soon as I go beyond 1/10th throttle it just losses all power. At low throttle it will run all the way to 4,000+RPM. But beyond a certain throttle position, regardless of RPM, it just goes limp. 2 months ago I performed a full tune, including valve adjust, pertronix, plugs, rotor, cap. I have triple checked my vacuum hose connections and electrical connections. I even pulled the throttle body off and checked the TPS operation, which appears to be operating properly. Oddly, my throttle body only has one port that goes to the back side of the vacuum advance diaphragm leaving the port on the front of the vacuum advance open. It definitely seems to be related to throttle position. Not sure where to try next. Any suggestions would be greatly appreciated. '74s have both an advance port and a retard port on the TB. Actually, '75s do, too. This is NOT debatable. Go look for them. The Cap'n |
| Brando |
May 3 2010, 12:26 AM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
To address this issue later on in Motronic cars, Bosch ran a ground wire from the wiper bridge to the wiper. It prevents issues like this from happening.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.efinnegan.com-2648-1272868011.1.jpg) More info on AFM rebuilding & diagnostics here. I opened up my air flow sensor and discovered the problem. The center tab connection had somehow twisted to the side and was no longer making contact with the center pole. If you look closely you can see the arrow pointing to the copper tang. Now the car is running like a top!! I'm so happy (IMG:style_emoticons/default/cheer.gif) |
| charliew |
May 3 2010, 08:34 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
Nice engineering change to know about. At first to me it looks like the placement of the wire might affect and limit the wiping action but I guess it can be observed and checked. I sure looks like it will cure a intermittent connection.
| wanchaiwarrior |
May 3 2010, 09:51 AM
The Cap'n [/quote] I removed the throttle body yesterday and looked. There is a boss on the opposite side, but it is not drilled. Perhaps this throttle body was replaced with an earlier version by a PO? |
| ClayPerrine |
May 3 2010, 01:07 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I normally agree with Cap'n Crusty, but on this I don't. Most of the 74s had an advance and a retard port on the throttle body. There were some that only had one. I can't say where the break point is, as all of the throttle bodies I have are off of engines that were out of the cars. I suspect it was very early 74 cars as the throttle body is identical to a 1.7 with the exception of the throttle switch...but I have no proof.
| Drums66 |
May 5 2010, 01:37 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
I'm surprised no 1 told you not to go inside there(AFM)
unless you really know what you are doing!!....it can be costly! (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/unsure.gif) |
| wanchaiwarrior |
May 5 2010, 02:16 PM
I'm surprised no 1 told you not to go inside there(AFM) unless you really know what you are doing!!....it can be costly! (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/unsure.gif) I did only as a last resort having exhausted all other options. I've learned through experience that 95% of the time I am able to fix most anything. Most of the time I get it right the first time, occasionally I don't and I pay the price. But the price is usually still less expensive than if I had turned it over to someone else who claims to be an expert. One thing is certain, if I do screw something up, I only do it once. |
| zonedoubt |
May 5 2010, 02:34 PM
Canadian Member ![]() ![]() ![]() Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
Great resource. I haven't seen that one before. I opened up my air flow sensor and discovered the problem. The center tab connection had somehow twisted to the side and was no longer making contact with the center pole. If you look closely you can see the arrow pointing to the copper tang. Nicely done. I had a problem with one of the other contacts. It was getting snagged on the rotor and would cause the engine to lose power under load. |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:27 AM |
