1971 6 cyl. Clutch cable hanging free |
xsurfer |
May 3 2010, 06:17 PM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
Hi Guys!
The clutch cable is hanging loose clear of the arm it attaches to, after a sudden let go. Did I loose a throw out bearing or bend and arm? Clutch cable appears not to be broken underneath the car. Any ideas. Car is bone stock! 88k orig. miles. HELP!!! Thanks Gene |
sixerdon |
May 3 2010, 08:55 PM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
If the cable is hanging loose, then chances are it snapped. Have someone step on the clutch pedal while you look under the car and see if the cable moves.
Don |
IronHillRestorations |
May 3 2010, 09:14 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Is it possible the clip that secures the cable to the pulley housing has broken? It's a special washer with a long tab that folds into the hole in the housing, and keeps the cable from coming off.
Lo-Fi Version | Time is now: 9th June 2024 - 03:04 AM |
