914zim |
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 ![]() |
Dudes:
I took the 914 out and washed it today. Also took a few pics while it was clean and out of the garage. I will try to attach a pic here, but am not sure it will work. Do you guys think it's sagging in the rear? I've looked at other pics of other cars and they didn't seem as saggy. Do I need springs and/or shocks? Thanks for any thoughts. Andy... Attached image(s) ![]() |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,350 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Looks high in the front to me
trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 931 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
Well I am no expert but it sure looks a little low on the back side (gives another meaning to "tail dragger"). I would not think that shocks would fix this problem, probably springs. The tires don't lean in at all do they? I am pretty sure that this is a spring issue, but people that know more than me will give you a better answer.
-Pete |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
adjust the T bars in front so its level.
TheCabinetmaker |
Andy, sorry for the poor attempt at humor. It does appear to sag in the rear. Prolly needs shocks and springs, but the front could still need to be lowered.
Rocky |
From the cockpit ![]() ![]() Group: Members Posts: 341 Joined: 24-March 04 From: Gig Harbor,WA Member No.: 1,845 ![]() |
Go with downin the torsion bars. Its sooo easy. Nice gas burners (IMG:style_emoticons/default/bootyshake.gif)
Tim |
nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
dude: definitely, lower the front. is it level, left-to-right? your springs may be a little worn and sagging. if it's just a street car for you (and it still drives/rides alright; nothing egregious), then just lower the front and drive (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif)
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,311 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
yup, the nose needs to come down ...
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
show us a picture of the car from the rear while it's resting on a level surface. when you adj the ride hight, measure it first, turn each adjuster about 1/2 a turn at a time, roll it back and forth a bit to settle the front end. measure and repeat. be patient.
kevin |
red914 |
...i believe in coyotes and time as an abstract... ![]() ![]() ![]() Group: Members Posts: 862 Joined: 8-February 04 From: poulsbo, washington Member No.: 1,641 ![]() |
its posture is almost exactly like mine before i learned (at the tacoma 914 breakfast) how to lower the front end. that adjustment seems to do the trick. the advice given above worked for me! (IMG:style_emoticons/default/clap56.gif)
now it seems to handle better at higher speeds. (IMG:style_emoticons/default/MDB2.gif) could it be the airdam is getting some effect now? (IMG:style_emoticons/default/burnout.gif) or is it just me imagining le mans? (IMG:style_emoticons/default/cool.gif) |
Rusty |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 7,987 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: South East States ![]() ![]() ![]() |
Nice looking car... I think the others have said it. Drop the front. It'll only take you about an hour. Drop the front a little bit with the torsion bar adjusting screws, take the car for a ride to let the suspension "settle in". Repeat as necessary.
A tip: Remember, when adjusting the torsion bar screws, that dropping the front left, will raise the rear right corner of the car. It works on a diagonal axis. {nit-picky mode on} Hey Rocky... those are 4 bolt Mahles. Only the 5 bolt versions are considered "gas burners." (IMG:style_emoticons/default/smile.gif) {anal retentive mode off} Have a great day! -Rusty (IMG:style_emoticons/default/smoke.gif) |
Curvie Roadlover |
Two trunks are better than one! ![]() ![]() ![]() ![]() Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 ![]() |
Don't forget to use a bump steer kit and it would also be wise to get an alignment after lowering the car
red914 |
ok, new guy question: why would Mahles (4 or 5 bolt) be called "gas burners." (IMG:style_emoticons/default/confused24.gif)
echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,109 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
cuz the look like the burner on a gas stove
914zim |
Dudes:
Thanks for all the responses. I gotta admit, I was hoping for the simple answer "you need springs", but I am glad I got the real scoop from you guys. I never would have thought to lower the front... this almost seems funny to me. I'm sure I could use springs and shocks (and a lot of other things), but for now I guess I'll look into lowering the front, cause it may not cost me anything. I still need to buy tires from Tire Rack today. Of course, not even knowing the front could be lowered on these cars, I have no clue (totally clueless) as to how to go about doing this. I'll go back and re-read the post and do a search on how to do this, but does anyone have a detailed explanation on how to lower the front? Is it just a matter of turning the torsion bar adjusting screws? Where are they? I'll get my Haynes. Thanks again fellas. I was sure I would get help and answers here. (IMG:style_emoticons/default/beerchug.gif) Andy... P.S. It's getting close to driving season here in WI... can't wait! Attached image(s) ![]() |
red914 |
i am sure one of the guys with a camera will post a picture. it is very simple; like Kevin, i believe, and others have said, measuring as you go, and moving the car to "settle it" a bit will do the trick. hey, if they can show me how to do it, it should be simple for anyone else! (IMG:style_emoticons/default/laugh.gif)
OT: i lived in delafield for three years back in the late 90s. still have many friends out there. in fact, went back for a wedding last november. (IMG:style_emoticons/default/beer3.gif) i was particularly impressed by the generous people of wisconsin. the humidity in the summer was punishing, however. oh, and the golf courses are gorgeous. |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
that 2nd picture helps a bit. My worry when people ask about a sagging rear always go to the suspension console. Your car looks even or possibly even higher on the passenger side, which bodes well.
Lo-Fi Version | Time is now: 7th September 2025 - 09:22 AM |
