Made a horn button today |
rick 918-S |
May 22 2010, 09:48 PM
Hey nice rack! -Celette Group: Members Posts: 20,473 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I really like the 914 four bar wheel without the butterfly cover but can't bring myself to cough up the money for the 912-911 GT button. (IMG:style_emoticons/default/screwy.gif) I was asking about button options a couple weeks ago. I think ury mentioned I could cheap out and get something from Home Depot. So I did.
I bought a 3" plastic cap, cut it off shorter and make a steel disc to fit inside. I used some plastic body clips for the three screws and assembled the disc to the cap by filling the void under the disc I made with fibre glas resin. The button fits as stock and will activate the horn. Sorry for the crappy photos. This is my first attempt I may make another one that isn't as tall. First photoshows the disc I made on the right. I covered the outside face of the disc with masking tape. This makes trimming resin overflow easier. The white blob is molding clay to make a hole or pocket in the resin for the rubber center. Next photo shows the disc screwed to the horn parts covered in tape to avoid being boneded by the resin filling the void under the disc. Once the resin set I pulled the horn part off the disc and trimmed the resin. If you look closely at the photo you can see the resin around the edge. |
rick 918-S |
May 22 2010, 09:50 PM
Horn part removed note the modeling clay is being extracted for the pocket for the rubber spring. If you look closely you can see the plastic threaded inserts imbedded in the resin below the disc.
Finished button. This was my first attempt. I think I can make this smaller/shorter. I learned alot from the first one. I think I may drill the four flats with three holes each to give the wheel a lightened race look. |
johannes |
May 23 2010, 01:57 PM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
Not bad for the first attempt ...
r_towle |
May 23 2010, 03:17 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
plumber (IMG:style_emoticons/default/poke.gif)
charliew |
May 23 2010, 04:06 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
As you go along you can use leather, maybe with a little tooling, with a little padding to cover one of them.
rick 918-S |
May 23 2010, 05:56 PM
Here's the GT with a side profile and mine. Mine has a little more arch to the top but the side doesn't look like it's that much taller.
Attached image(s) |
underthetire |
May 23 2010, 06:01 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Looks good. I happen to have a yellow round disk with the Porsche crest engraved in it in red. Might be able to turn the front of it flat and insert this. You can have it if you want it. It's at work but I can bring it home.. Maybe look ok, maybe not.
rick 918-S |
May 23 2010, 07:29 PM
Looks good. I happen to have a yellow round disk with the Porsche crest engraved in it in red. Might be able to turn the front of it flat and insert this. You can have it if you want it. It's at work but I can bring it home.. Maybe look ok, maybe not. Cool! PM sent. Eventually I would like to pull a mold off of a GT center but like I said. I have plenty of places to put my money with the Alien needing a transaxle repair and the two other 914's I just bought and the Shealey and and and.... This is not nearly as cool as the GT but it was fun trying to see if I could do it. |
underthetire |
May 23 2010, 07:46 PM
Ya know, if a guy had a CNC mill, and a little time, he could make one out of aluminum. (IMG:style_emoticons/default/idea.gif)
Or a guy with a CNC Lathe with live tooling... |
914coop |
May 23 2010, 10:06 PM
Member Group: Members Posts: 214 Joined: 5-September 08 From: Minneapolis Member No.: 9,514 Region Association: Northstar Region |
Looks nice Rick, It was hard to figure out the guts when I saw the white disk last Sunday.
Lo-Fi Version | Time is now: 1st June 2024 - 07:26 AM |
