> Getting Tranny Into Neutral
adambo
post May 31 2010, 10:40 PM
I have my motor sitting on the floor and I'm trying to start it, with a strong battery the starter can't get it spinning fast enough to start. The tranny is in gear and i think thats the problem, how do I get it into neutral?
-Adam
Replies(1 - 8)
detoxcowboy
post Jun 1 2010, 08:03 AM
Region Association: Africa
neutral is in the center postion 90 deg from the tranny.
EdwardBlume
post Jun 1 2010, 08:10 AM
The gear selector will also move up and down freely which is the play for neutral...
underthetire
post Jun 1 2010, 10:13 AM
Are you using jumper cables to try to start it?
adambo
post Jun 1 2010, 02:23 PM
I'm using a strong battery with one of those battery chargers and I took the belt off the alternator. Any advice? Also I found neutral but its weird, I can spin the CVs by hand and the motor doesn't turn over, but while still in neutral when I hit the starter the CV's still spin.
underthetire
post Jun 1 2010, 02:30 PM
Again, are you using jumper cables, from your battery to the starter?
adambo
post Jun 1 2010, 02:33 PM
No, sorry I misunderstood you. I pulled the actual cables from the car.
jaxdream
post Jun 2 2010, 07:19 AM
It's normal for the trans output flanges to turn when in neutral , the is no weight from the car on the suspension holding the cv / axle shafts / wheels and tires in place . You didn't mention if the motor was rebuilt or not , running before the motor pull , what condition of tune , carbs or stock f inection. More info will get a bigger picture.
Jack / Jaxdream
underthetire
post Jun 2 2010, 08:21 AM
QUOTE(adambo @ Jun 1 2010, 01:33 PM) *
Good, just checking. I've seen others try to use jumpers and they never work for that.
- Lo-Fi Version Time is now: 26th August 2026 - 07:18 AM
