FS 914-6 Engine Shroud Cooling Tin in Fiberglass $100.00 |
sww914 |
Jun 7 2010, 01:26 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
I only have the front and the sides. You will need a back piece too, it directs the cooling air around the oil cooler. Another rear piece is available in metal from GPR for around $100.00, and you can probably get Getty Design, GT Racing, A.I.R, or Roger Sheridan to make you a fiberglass one separately. This one has it's share of scratches and a couple of the mounting holes are kind of blown out, you can still install it using larger washers.
Steve (805)215--02-43! Attached thumbnail(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:39 PM |
