L-jet fuel pump question |
High Path |
Jun 22 2010, 02:40 PM
Newbie Group: Members Posts: 26 Joined: 29-June 09 From: Edina, MN Member No.: 10,516 Region Association: Upper MidWest |
I have a 1974 1.8
while the car is idling I can hear the fuel pump running (it is a non-Porsche part, moved to the front trunk by PO), however it isn't running consistently. I hear it wax and wane over the period of a few seconds. Kind of like a rotating tornado siren, only faster (and quieter (IMG:style_emoticons/default/smile.gif) ) So here is my question... is this normal, or should it be running at a constant pitch whenever the car is running. If it is normal for it to wax and wane, what signal is telling the pump to slow down, then speed up again, all while under a constant load (parked and idling). The reason I ask is that the fuel pump hasn't run for a year, and I just recently got it running (high resistance connection on relay board, subject for another post). Last year the car ran well enough to take out on the highway, but I thought I was hearing a continuous pitch from the fuel pump. Now the car cuts out on acceleration and struggles to go around the block. Thanks |
Cupomeat |
Jun 22 2010, 02:43 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
As these Bosch FI system use a closed loop fuel system, with a regulator, the pumps should run at a constant pitch and rate, all the time.
Check the electrical connections on this one and continue trouble shooting from there. On my L-jet with a stock pump (35 yrs old) and stock mounting, I cannot hear the pump, ever. ...btw, that is not because the car does not run, (IMG:style_emoticons/default/happy11.gif) |
High Path |
Jun 22 2010, 03:12 PM
Thanks, that was my understanding of how they should work too. I just wanted to confirm that.
I had a problem getting adequate voltage to the pump, and it wasn't running at all. I thought I'd solved that, but it appears I've just partially solved it. I used to be annoyed at the fuel pump noise, but at this point it is proving extremely usefull in debugging this. As the software guys would say, "it's not a bug, it's a feature!" |
Cupomeat |
Jun 22 2010, 03:21 PM
I am glad I could help.
I find that when the L-jet is running poorly, it really sucks, but when it is running great, it is a VERY reliable FI system. I guess that should be obvious as Bosch used that L-Jet system as the basis for almost all its Electronic injection systems going forward (Non CIS, which is mechanical). heck, even the motronic systems can be traced back to the L-Jet. |
Drums66 |
Jun 22 2010, 03:39 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
[quote name='Cupomeat' date='Jun 22 2010, 01:43 PM' post='1333827']
On my L-jet with a stock pump (35 yrs old) and stock mounting, I cannot hear the pump, ever. I think that signal's a problem(noise) (IMG:style_emoticons/default/sad.gif) |
ClayPerrine |
Jun 23 2010, 05:58 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I am glad I could help. I find that when the L-jet is running poorly, it really sucks, but when it is running great, it is a VERY reliable FI system. I guess that should be obvious as Bosch used that L-Jet system as the basis for almost all its Electronic injection systems going forward (Non CIS, which is mechanical). heck, even the motronic systems can be traced back to the L-Jet. Just to correct, the CIS is a hydraulic fuel system, not mechanical. CIS and MFI are two completely different systems. The L-Jet system evolved into the Bosch Motronic system used on the 924S/944s, some 928s (IIRC), the 911 3.2 Carrera, the 964, the 993, 996, and 997. A licensed Nippondenso copy of the L-Jet system is also used on almost all the Nissan and Toyota models built during the 80s and 90s. Now addressing the problem. No the fuel pump should not vary in sound. I would suggest that you take your engine lid off, and put a fuel pressure gauge on that you can tape to the back window and see in your rear view mirror. Then go drive it and see if the pressure varies. Granted, and L-Jet system should vary from 28 to 34 PSI, but anything outside of that can indicate either a pump problem, a problem with the inlet side of the tank, a regulator problem, or a blocked return line. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:42 PM |
