FS: Raised and Gusseted Koni Struts, 3.5" Brake Caliper Mounting Ears |
Eric_Shea |
Aug 11 2010, 08:10 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
For sale is a pair of raised and gusseted Koni struts.
The spindles have been raised 18mm and seam welded along the top and bottom (common failure on raised struts is the rosette weld). They have also been gusseted with RSR style gussets on the spindle. I recently removed these from my 911 as it is going back to a more “stock” trim. The struts were soda blasted to bare metal and then powder coated (not paint) in the proper orange. New decals were acquired from Koni and you have what you see here. I’m also including a set of stock Koni inserts. These are the inserts that actually come with these struts from the factory. I was informed that Clint over at Rebel Racing can rebuild these inserts for around $75.00 each. I believe these are slightly superior to the aftermarket Koni inserts as they have better cooling without the second sleeve Asking $695.00 plus shipping OBO |
Eric_Shea |
Aug 11 2010, 03:14 PM
S-O-L-D... sold.
Lo-Fi Version | Time is now: 1st June 2024 - 03:16 PM |
