Starter won't crank |
Geezer914 |
Aug 19 2010, 12:00 PM
Geezer914 Group: Members Posts: 1,424 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Starter won't crank over when you turn the key, but turns over with a remote start switch. Replaced the ignition switch, but no help??????
Tom |
Aug 19 2010, 12:05 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
You will need to check all of the connections between the ignition switch and the starter solenoid. Seat belt relay under passenger seat, there are two on the relay board alone, and then the relay board itself. Also the connector at the solenoid on the big yellow wire. Is it in good condition? Especially at the crimp.
Tom |
Drums66 |
Aug 19 2010, 04:17 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
...once again, clean all grounds,cable's, & connection's of green(corrosion) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif)
Lo-Fi Version | Time is now: 23rd May 2024 - 02:59 AM |
