| kfish914 |
Aug 23 2010, 10:13 AM
Member ![]() ![]() Group: Members Posts: 161 Joined: 7-May 08 From: Osceola, Indiana Member No.: 9,026 Region Association: Upper MidWest |
This may be a stupid question...however my dad always said the only stupid questions are the ones not asked.
I am converting to a 2.7 six and I wanted to dress up the front compartment a little and add a removable felt covered board above the gas tank to hide the hoses and water bottle etc. I would have a cut out for the filler and the brake. It would be a lot easier to make it fit if I didn't have the expansion tank in place. What do you guys think. |
| tradisrad |
Aug 23 2010, 10:24 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I think you need some sort of expansion tank or a way to vent the gas tank that does not fill the cab with gas fumes. Dont forget the charcoal canister is also part of the system. It really has nothing to do with the engine that is installed.
| kfish914 |
Aug 23 2010, 10:32 AM
Is it even a good idea? Or by closing off this area will I make the chance of a gas fume issue an even bigger issue.
| ClayPerrine |
Aug 23 2010, 10:54 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
From experience... put the expansion tank on, and put the charcoal canister on. I left them off, and the gas smell inside the car was overwhelming. And it got worse when it was hot.
Plus, hooking them up costs nothing.. not even horsepower. And it helps the environment. Just my $.02 |
| IronHillRestorations |
Aug 23 2010, 11:26 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,927 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
There's no good reason not to use the expansion tank and charcoal canister. Collecting fuel vapors is not a bad thing. |
| SLITS |
Aug 23 2010, 11:45 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
If it bothers you that bad, mount it in the engine compartment like the later cars
| kfish914 |
Aug 23 2010, 12:08 PM
It doesn't bother me, I think it is a good thing to have for the environment. I was just thinking(being lazy) about not having to cut the angles for the board to fit well around the expansion tank and look professional.
Thanks for the input I think I will just take my time and do it "right" and make it look good with the expansion tank in place. By the way I was messing around with my GPS and found it will fit in the ash tray when closed ( a little modification on the tray). I need to install a stronger spring so it will open up better when i pull it open. |
| Jeffs9146 |
Aug 23 2010, 01:22 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE mount it in the engine compartment like the later cars (IMG:style_emoticons/default/agree.gif) You can mount them to the left of the brake filler or in the engine compartment! I have seen them in 3 different places! So if it is in the way, move it! |
| elmonte |
Aug 23 2010, 05:27 PM
Member ![]() ![]() Group: Members Posts: 225 Joined: 31-March 03 From: Danville.ca Member No.: 499 |
Here's one (not mine) that seems to high enough to clear the tank.
![]() Cheers |
| kfish914 |
Aug 24 2010, 07:11 AM
It looks like they removed the expansion tank from around the filler.
I looked at my car again and the charcoal canister is in the engine bay. the small tank that only had a small(5mm) hose that went out to the bottom of the car that surrounds the gas filler neck area is what I was thinking about removeing for a cleaner look when I place the board in that area. In the picture it looks like the gas filler neck is still in tack but the expansion tank has been removed, hard to see the details completely. |
| SirAndy |
Aug 24 2010, 10:59 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Do I need the expansion chamber on a 6 conversion How much do you like the smell of gas? (IMG:style_emoticons/default/biggrin.gif) I removed mine including the charcoal canister etc. and i wouldn't do that again. I always have fuel smell in the car when the tank is above 1/2. (IMG:style_emoticons/default/dry.gif) Like others have said above, you could relocate it ... (IMG:style_emoticons/default/idea.gif) Andy |
| Root_Werks |
Aug 24 2010, 11:48 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,930 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
After completing the conversion from carbs back to stock FI, I made sure to install the charcoal can and related lines etc. since the PO just had the vent tube sitting open to the air under the car.
I noticed right away, no more smell of gas in the garage. NICE! (IMG:style_emoticons/default/smilie_pokal.gif) I'd vote for keeping it all hooked up like it should be. It's embarassing when your car, any car stinks of anything. |
| jflash914 |
Aug 24 2010, 12:58 PM
Member ![]() ![]() Group: Members Posts: 80 Joined: 24-February 05 From: binghamton,ny Member No.: 3,652 |
Kfish,
Here is a picture of the cover over my gas tank. I used two pieces. Jack |
| jflash914 |
Aug 24 2010, 01:00 PM
Trying to add the picture.
| SirAndy |
Aug 24 2010, 01:04 PM
| jflash914 |
Aug 24 2010, 01:16 PM
last try
| sixerdon |
Aug 24 2010, 04:57 PM
Member ![]() ![]() Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
This may be a stupid question...however my dad always said the only stupid questions are the ones not asked. I am converting to a 2.7 six and I wanted to dress up the front compartment a little and add a removable felt covered board above the gas tank to hide the hoses and water bottle etc. I would have a cut out for the filler and the brake. It would be a lot easier to make it fit if I didn't have the expansion tank in place. What do you guys think. You didn't say if you are keeping the CIS or going to carbs. If you go with carbs, you don't need the evaportion control system. Sixes sold in California had to have it, but the other 47 states and Rest of World did not. The 47 state /6 does not/never had the charcoal canister. However, the expansion tank vents to the atmosphere via a "Y" connection to the tank over-fill hose and vents below the car. You can remove the expansion tank and vent from the filler neck to the "Y" connection and you will have a clean top for your carpet. Just don't spill gas on it. I have never figured out why the expansion tank was installed in non-Cali sixes since it vents to the atmosphere anyway just like the carbs do. And, I have never had a problem with vapors. Don |
| kfish914 |
Aug 25 2010, 06:41 AM
Jflash914 that looks very nice and in line with what I was thinking of doing.
What did you use and do you have any tips ? I was thinking about using 1/4 MDF and felt to match the felt in the trunk. Iwould like to use one piece but I think I may have to use two separate pieces to fit well. I will be covering the rest of the trunk with felt like Porsche did with the 916. To answer the other question I will be keeping the CIS. |
| Mountain914 |
Aug 25 2010, 12:36 PM
Too much time in thin air! ![]() ![]() Group: Members Posts: 367 Joined: 22-May 03 From: Conifer, CO Member No.: 725 Region Association: Rocky Mountains |
Wow Jack, that looks great !
With no spare, mine looks positively cavernous (I'm sure I could fit a few dead zombies in there). (IMG:http://www.914world.com/bbs2/uploads/post-725-1277906065.jpg) And to stay on topic, I do get a gas smell (from the car - not me!), but only on sharp left turns. Therefore I take three rights to go left. |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:17 PM |
