| PanelBilly |
Aug 26 2010, 10:56 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
I saw the thread about using gloves to thighen the return spring, but no how to. My biggest problem is they don't pull out easy and get stuck.
| underthetire |
Aug 26 2010, 11:02 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
All I can tell you is two things, silicon lube works well for the sticking problem. And if you remove the plastic cover over the spring a giant snake pops out.
| JRust |
Aug 26 2010, 11:28 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Yeah I haven't tackled seat belts before. A how too would be great & seems like I have read a post somewhere on it. Someone pipe in here with the link
| dr914@autoatlanta.com |
Aug 26 2010, 11:35 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,231 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we really have not investigated their repair as we have many many used and nos on the shelf and it is such a safety issue that we do not "fool" with their guts!!!!
| JmuRiz |
Aug 26 2010, 01:15 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,619 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
I haven't done it myself, but I remember someone mentioning that if you straightened the belts out (had them in tension) then gave them a spray of scotchguard and let them dry they seemed to retract better.
Maybe I pulled that out of my @$$, but I thought that's what they did... edit: found something http://www.914world.com/bbs2/index.php?sho...;hl=scotchguard http://www.914world.com/bbs2/index.php?s=&...st&p=398085 |
| Jerry75914 |
Aug 26 2010, 01:53 PM
Member ![]() ![]() Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California |
I found I couldn't get mine to unroll once I rolled them up really far for storage...took the cover off to see if I could free it...and dang near lost an eye as the "snake" spring from hell flew out of there. Putting it back sucked royally, actually had to do it twice, but it does pull in better now. Given the ass-pain involved...get a better unit vs. re-building.
| underthetire |
Aug 26 2010, 02:00 PM
Actually, for the roll up problem, you wash them on woolite. Scotchguard will make them even harder. The pull out problem is simply remove the cover for the cam side and put a few drops of lubricant in the mechanism. Did mine a while back and WAY better now. I had the jack-in-the-seatbelt on the first one to. 3 trys and I got it back together. I think it was the wider cover that was OK to remove. There is a member here that charges a small fee to take them apart and add tension on the spring for roll up.
| BigDBass |
Aug 26 2010, 03:20 PM
Dumb Question Champion ![]() ![]() ![]() Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
I haven't done it myself, but I remember someone mentioning that if you straightened the belts out (had them in tension) then gave them a spray of scotchguard and let them dry they seemed to retract better. Maybe I pulled that out of my @$$, but I thought that's what they did... edit: found something http://www.914world.com/bbs2/index.php?sho...;hl=scotchguard http://www.914world.com/bbs2/index.php?s=&...st&p=398085 I tried the Scotchguard thing and it didn't result in much, if any, improvement. |
| Joe Owensby |
Aug 26 2010, 07:10 PM
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Do not release the springs from beneath the cover. The springs can be rewound fairly simply. Pull the entire length of the belt from the reel. Then, with a dull screw driver, push the loop on the belt back through the slot in the center of the reel, while holding the reel to keep it from turning. I used a pair of vise grips to lightly grip the reel to keep it from turning. When the belt is pushed back in, you can see a pin that goes through the loop in the belt. Remove the pin, and then pull the belt out. You can then use two screw drivers to incrementally either unwind or rewind the spool. When you get it to the point you want it, just re-install the belt through the slot, insert the pin, and pull the belt so that the pin goes back into the groove in the slot. This can all be done without removing the cover on the spring. There is a thread somewhere showing this. JoeO
| jsaum |
Aug 27 2010, 10:49 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
Billy,
I'm not sure he's still doing them but, PRS914-6 is the one member who can tighten the springs. Jsaum |
| PRS914-6 |
Aug 27 2010, 11:03 AM
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
Do not release the springs from beneath the cover. The springs can be rewound fairly simply. Pull the entire length of the belt from the reel. Then, with a dull screw driver, push the loop on the belt back through the slot in the center of the reel, while holding the reel to keep it from turning. I used a pair of vise grips to lightly grip the reel to keep it from turning. When the belt is pushed back in, you can see a pin that goes through the loop in the belt. Remove the pin, and then pull the belt out. You can then use two screw drivers to incrementally either unwind or rewind the spool. When you get it to the point you want it, just re-install the belt through the slot, insert the pin, and pull the belt so that the pin goes back into the groove in the slot. This can all be done without removing the cover on the spring. There is a thread somewhere showing this. JoeO This works OK but the problem is that the belts typically need to be tightened much more than this method can deliver. You can only wind the spring up until it binds and then insert the pin/belt I leave numerous wraps on the belt around the spool, then pull the cover off (DANGER!!)and wind the spring even further. This method loses some belt length but unless you are a size 44 waist, you'll never even know. The advantage is that you get a firm retracting belt that works the way it's supposed to. 90% of the belts I have seen won't retract properly without leaving some wraps around the spool and then fully tightening the spring. Also, I wouldn't use any oil on the mechanism. It will attract dirt and could cost you your life. A good cleaning and a wee bit of graphite works well YMMV..... |
Lo-Fi Version | Time is now: 3rd March 2026 - 12:27 PM |
