| BCinSC |
Sep 7 2010, 01:47 PM
Nothing but Trouble ![]() ![]() Group: Members Posts: 138 Joined: 8-June 03 From: Wakefield, MA Member No.: 800 Region Association: North East States |
rough running
stalls at idle backfires 0-50 takes several minutes (notice I didn't say 60 - can't hit that) strong smell of raw gas all speaks to at least one cylinder not firing No visible signs of leaking fuel. 2 new injectors don't seem to have helped Trigger and Ignition points replaced Ignition wires checked and rechecked Timing was supposedly set, but will check myself when I get home. Why is this thing so cranky? |
| 7TPorsh |
Sep 7 2010, 01:57 PM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
Firing order?
| djm914-6 |
Sep 7 2010, 01:58 PM
Happiness is: Getting on the road ![]() ![]() ![]() Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
All that time and money and it still isn't right??? Can you tell Autobahn to fix it once and for all and not pay anymore. This is ridiculous!
| BCinSC |
Sep 7 2010, 02:09 PM
I called Autobahn this morning, after the white knuckle drive into work, and let Mike know how disappointed I was.
| BCinSC |
Sep 7 2010, 02:10 PM
Thing is, initial cold start seems OK. As it warms, it gets progressively worse to the point of undrivable.
| Bartlett 914 |
Sep 7 2010, 02:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
rough running stalls at idle backfires 0-50 takes several minutes (notice I didn't say 60 - can't hit that) strong smell of raw gas all speaks to at least one cylinder not firing No visible signs of leaking fuel. 2 new injectors don't seem to have helped Trigger and Ignition points replaced Ignition wires checked and rechecked Timing was supposedly set, but will check myself when I get home. Why is this thing so cranky? CHT could be bad. Could also be a bad ECU. |
| Root_Werks |
Sep 7 2010, 03:30 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,996 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Wow,
This sounds like a simple fix. Already mentioned to check the CHT, shoot, just buy a new one and install it. Why even mess with it, cheap. There's only a couple of things on D-Jet that cause such rich running conditions, here are a few that I can recall off the top of my big head/little brain: CHT bad ECU bad - I had one once that made my 914 run really, really rich. Trigger points bad - I think I noted you already replaced those Bad injector(s) - not closing Cold start injector staying open There are others, but those are usually the common ones. Make a list, go through each one at a time. You'll get it. (IMG:style_emoticons/default/driving.gif) |
| Root_Werks |
Sep 7 2010, 03:31 PM
| BCinSC |
Sep 8 2010, 05:28 AM
Work done at reputable shop
CHT - replaced <20K ago. Do they go bad often? Can I test it's functionality? Just a resistance value, correct? Trigger points replaced last summer and again this last visit to shop - seems like they are ruled out. Yes, '73 has cold start injector and always suspected it was malfunctioning. However, engine is rough even cold and especially under any load. 2 brand new injectors this summer and other 2 tested out of engine for spray pattern at shop and were OK What is AAR? Could dizzy be failing to advance? Stuck weights? It seems to move freely cold , but I've never held it hot. |
| Lennies914 |
Sep 8 2010, 07:20 AM
Slacker ![]() ![]() ![]() Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
AAR= auxilary air regulator. Open when cold, closes when hot. If stuck, it will be a huge vacuum leak. Again, easily checked. With engine warmed up, remove the AAR vacuum line from the air box side, there should be no vacuum.
| 76-914 |
Sep 8 2010, 08:19 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,893 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Work done at reputable shop CHT - replaced <20K ago. Do they go bad often? Can I test it's functionality? Just a resistance value, correct? Trigger points replaced last summer and again this last visit to shop - seems like they are ruled out. Yes, '73 has cold start injector and always suspected it was malfunctioning. However, engine is rough even cold and especially under any load. 2 brand new injectors this summer and other 2 tested out of engine for spray pattern at shop and were OK What is AAR? Could dizzy be failing to advance? Stuck weights? It seems to move freely cold , but I've never held it hot. Are they reputable w/ 914 owners or the pinky rings? Sounds as if they aren't familiar w/ our 914's. |
| trent1542 |
Sep 8 2010, 08:50 AM
Member ![]() ![]() Group: Members Posts: 98 Joined: 19-August 10 Member No.: 12,074 Region Association: Pacific Northwest |
maybe your timing is off?
| Root_Werks |
Sep 8 2010, 08:54 AM
| trent1542 |
Sep 8 2010, 09:50 AM
| TheCabinetmaker |
Sep 8 2010, 10:15 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
maybe your timing is off? Yup, could be that, vac hose connected or disconnected when timing set? Vac hose hooked up to correct side of can? Those make a huge difference. what about the timing chain? (IMG:style_emoticons/default/lol-2.gif) Its a 4 cly Trent! It ain't got no stinking timing chain! |
| trent1542 |
Sep 8 2010, 04:57 PM
maybe your timing is off? Yup, could be that, vac hose connected or disconnected when timing set? Vac hose hooked up to correct side of can? Those make a huge difference. what about the timing chain? (IMG:style_emoticons/default/lol-2.gif) Its a 4 cly Trent! It ain't got no stinking timing chain! whoops forgot about the 4 cylinder part, just rebuilt a jeep liberty 6 cylinder and I had such a hard time with the timing chain. (IMG:style_emoticons/default/av-943.gif) |
| jk76.914 |
Sep 8 2010, 05:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
ruptured MPS? Have you checked to see if it holds vacuum?
Jim |
| Cevan |
Sep 8 2010, 06:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
What service did the shop perform for the $1800?
| scotty b |
Sep 8 2010, 06:53 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Take the intake manifold off and look for a 3 way vauum hose. It cracks, it cannot be seen with the main plenum on , and it will casue all of these issues. I know because years ago I pulled an engine to rebuild it convinced it was in need, ended up finding that piece was hard as a wedding dick and split in 2.
| scotty b |
Sep 8 2010, 07:09 PM
Take the ( " air filter " in the diagram )off and look for a 3 way vauum hose. It cracks, it cannot be seen with the main plenum on , and it will casue all of these issues. I know because years ago I pulled an engine to rebuild it convinced it was in need, ended up finding that piece was hard as a wedding dick and split in 2. O.k. slight brain fart. It is not a 3 way vacuum line it is a 3 way metal thingy ma hooch and it has a hose that makes a awkward angle to the plenum. thereis also a line on the underside, that can't be seen. This diagram only shows the 2 on the top 13mm one to the filter housing and one to the boot. I don't recall where the one on the underside goes. Attached image(s)
Lo-Fi Version | Time is now: 9th June 2026 - 02:19 AM |
