no control over intermittent wipers |
motomadness1947 |
Sep 11 2010, 08:50 AM
Newbie Group: Members Posts: 35 Joined: 9-May 10 From: smyrna, tn Member No.: 11,709 Region Association: None |
When i got my 74 2.0 fi the windshield wipers and heater fan did not work, so this weekend I finally got round to check why. Lo, the number 8 fuse had been pulled. When i put it back in. I found that the wipers work in an intermittent function when the switch is in the off position. My switch is on the column and is the normal off slow and fast positions.
Does any one know the cause of the intermittent function or should I say malfunction? and how to stop it. |
dr914@autoatlanta.com |
Sep 11 2010, 09:50 AM
914 Guru Group: Members Posts: 7,885 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Of course all of the way down is intermittent. If they are working when the switch is one click up (the off position) the ground lead under the steering wheel under the lower turn signal wiper securing screw is loose. Typical. This is well covered in the 914"Tech Tips 700" book by Dr. 914!
When i got my 74 2.0 fi the windshield wipers and heater fan did not work, so this weekend I finally got round to check why. Lo, the number 8 fuse had been pulled. When i put it back in. I found that the wipers work in an intermittent function when the switch is in the off position. My switch is on the column and is the normal off slow and fast positions. Does any one know the cause of the intermittent function or should I say malfunction? and how to stop it. |
jim_hoyland |
Sep 11 2010, 10:35 AM
Get that VIN ? Group: Members Posts: 9,313 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
It's all there on page 89...
Attached image(s) |
Sep 11 2010, 10:41 AM
jim_hoyland |
Sep 11 2010, 10:56 AM
Drums66 |
Sep 11 2010, 11:13 AM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
with your next order I will send you a fresh copy Jim for free!!! It's all there on page 89... Photo copy this page! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 05:37 AM |
