| 913B |
Nov 8 2010, 05:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 864 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
So I ask the FLAPS parts person for fuel line hose and he gives me this. Then I check online with the SAE J30R7 rating stamped on the hose. It says operating PSI is 50 and burst psi is 250.
http://www.goodyearep.com/ProductsDetail.aspx?id=10526 Is it safe ? Perhaps some members with deeper knowledge can confirm?? If so whats with the warning of dont use on FI cars ? Maybe modern FI cars and not the ones like 39 years ago maybe. Thank you all !! Ted (IMG:style_emoticons/default/beerchug.gif) |
| underthetire |
Nov 8 2010, 05:24 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Buy the injection hose with the colored liner. Our wonderful fuel here eats anything else up.
| jk76.914 |
Nov 8 2010, 05:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
Correct lines are 7mm ID x 3mm wall, with means the OD is 13mm. I've seen this sold as both 7x3 and as 7x13, and it ain't cheap. That 5/16" fuel line is almost 8mm in ID. You may get it to seal with a tight clamp, but it'll too easily leak when it thermal cycles and starts to loose its stretch. Even Goodyear says it isn't for fuel injection.
I've heard of some people using BMW 7.5mm lines, but I'd stick with the right stuff. Too many 914's have burned up because of engine fires, and even the factory did a recall to replace the original cloth-braided 7x12 lines with these. I also wouldn't go with 50 psi working pressure. That doesn't even give you a 2x safety margin.... While you're at it, be sure and get the correct clamps. Standard gear style clamps can cut through the outer skin of the hose, and lead to leaks later, or worse. |
| ChrisFoley |
Nov 8 2010, 06:06 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Correct lines are 7mm ID x 3mm wall, with means the OD is 13mm. I've seen this sold as both 7x3 and as 7x13, and it ain't cheap. That 5/16" fuel line is almost 8mm in ID. Have you ever actually measured the od of the tubes that the fuel hose fits onto? Modern 7.9mm id hose is plenty tight on all the fittings you say need 7mm hose for a proper fit. It will never leak if the correct clamps are used. However, if it isn't rated for FI don't use it for FI. |
| jk76.914 |
Nov 8 2010, 06:27 PM
| 913B |
Nov 8 2010, 07:17 PM
Hmm, thanks for the good advice.
| realred914 |
Nov 8 2010, 07:38 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
5/16 inch is a great fit, wont fail with clamps. the 30R9 NOT the 30R7 is to be used, the 3R9 is lined with a flouropolymer (Teflon like) inner hose that resists the new gasolines (oxygenated fuel) use of the older 30R7 hose is NOT recommended with todays fuels. as the hose degrades the 50 psi rating degrades. Orignal style German hose is NOT lined and is NOT recommended anymore becuase of the changes in fuel mixture.
look for SAE 30R9 rating stamped on your hoses, if not there, dont use it. |
| Rotary'14 |
Nov 8 2010, 07:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
5/16 inch is a great fit, wont fail with clamps. the 30R9 NOT the 30R7 is to be used, the 3R9 is lined with a flouropolymer (Teflon like) inner hose that resists the new gasolines (oxygenated fuel) use of the older 30R7 hose is NOT recommended with todays fuels. as the hose degrades the 50 psi rating degrades. Orignal style German hose is NOT lined and is NOT recommended anymore becuase of the changes in fuel mixture. look for SAE 30R9 rating stamped on your hoses, if not there, dont use it. So we should be using SAE 30R9 (FI fuel hose) for all our fuel line needs, even carbs? This is good info as I didn't know how aggressive new fuel blends have become. -Robert |
| realred914 |
Nov 8 2010, 08:07 PM
5/16 inch is a great fit, wont fail with clamps. the 30R9 NOT the 30R7 is to be used, the 3R9 is lined with a flouropolymer (Teflon like) inner hose that resists the new gasolines (oxygenated fuel) use of the older 30R7 hose is NOT recommended with todays fuels. as the hose degrades the 50 psi rating degrades. Orignal style German hose is NOT lined and is NOT recommended anymore becuase of the changes in fuel mixture. look for SAE 30R9 rating stamped on your hoses, if not there, dont use it. So we should be using SAE 30R9 (FI fuel hose) for all our fuel line needs, even carbs? This is good info as I didn't know how aggressive new fuel blends have become. -Robert YEs, even with carbs i use it, as it should be longer lasting and safer in the long run. |
| 913B |
Dec 11 2010, 08:31 PM
So I am back to fuel line replacement project. So wondering if any had a source for SAE 30R9 (FI fuel hose) ??
Thanks in Advance. Ted |
| bandjoey |
Dec 11 2010, 11:17 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I don't know the ratings. A year ago I bought the proper metric FI lines from Al Zim (www.allzim.com) and it was expensive with a cap E. Might check their site or call them. They have stuff not on the www. I don't remember seeing any kind of liner.
Is the liner separate and visible to the eye or bonded into the rubber? Tomorrow I'll look to see what number is on that line. |
| patssle |
Dec 11 2010, 11:29 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
When you guys say the R7 degrades because of the fuel we use these days, how long does it take roughly - obviously depending on use?
| underthetire |
Dec 12 2010, 12:17 AM
Well, the one piece I replaced with the R7 stuff showed cracks 1 year later. I was short 12" on one run, all else was R9 and looks like new. Available at Flaps, it's about twice the money as the old stuff.
| dangrouche |
Dec 12 2010, 01:35 AM
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
R9 rated hose; cut by the foot, cost about $7 per foot, got it at Kragens; it has a blue liner, you can't miss it. I have installed for my Djet. been in place for the last year or so without any problems
| AvalonFal |
Dec 12 2010, 11:01 AM
Member ![]() ![]() Group: Members Posts: 487 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
I posted this pic a while back, but here's an example of a PO using the wrong type fuel hose.
Paul ![]() |
| realred914 |
Dec 12 2010, 11:21 AM
| 76-914 |
Dec 12 2010, 12:39 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
| jk76.914 |
Dec 12 2010, 07:53 PM
Does anybody make the elbow hoses to the fuel injectors?
| type11969 |
Dec 12 2010, 08:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
Hoses to the fuel injectors are the same hose as elsewhere.
Decent price for SAE 30R9: http://cgi.ebay.com/ebaymotors/Goodyear-Fu...sQ5fAccessories Got some on the way . . . -Chris |
| Cupomeat |
Dec 12 2010, 09:14 PM
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,349 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Hoses to the fuel injectors are the same hose as elsewhere. Decent price for SAE 30R9: http://cgi.ebay.com/ebaymotors/Goodyear-Fu...sQ5fAccessories Got some on the way . . . -Chris Ok, I can handle the $4.60 a foot, but the shipping charges are illogical! $2.00 for the first foot (which is ok) but $0.75 for each foot up to 15...? Reminds me of the old J.C. Whitney charge to ship based on cost, not what the part was. |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:13 PM |
