Last thing you want to see...., ....under the hood of a 968. |
Series9 |
Nov 13 2010, 05:36 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
This happened to Nelson today while I was visiting: Attached image(s) |
jimkelly |
Nov 13 2010, 05:38 PM
i take it this is an interference engine?
Series9 |
Nov 13 2010, 05:40 PM
dion9146 |
Nov 13 2010, 05:41 PM
Member Group: Members Posts: 469 Joined: 16-May 04 From: Buckner, KY Member No.: 2,071 Region Association: MidAtlantic Region |
okieflyr |
Nov 13 2010, 06:41 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
Sorry about that Nelson. (IMG:style_emoticons/default/sad.gif) It may be cheeper to put an LS1 in there and have a sleeper. (IMG:style_emoticons/default/biggrin.gif)
rick 918-S |
Nov 13 2010, 06:53 PM
Hey nice rack! -Celette Group: Members Posts: 20,470 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Oooohhh... That'll leave a mark! (IMG:style_emoticons/default/dry.gif) Maybe you'll get lucky and it will only be bent valves not broken pistons and gouged cylinder walls from the broken pistons. Ask me how I know... (IMG:style_emoticons/default/pinch.gif)
sixnotfour |
Nov 13 2010, 07:33 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
chev it
Attached image(s) |
KaptKaos |
Nov 13 2010, 08:19 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
What is the disadvantage of a non-interference engine?
Rick L |
Nov 13 2010, 08:22 PM
Member Group: Members Posts: 405 Joined: 12-November 05 From: Columbia-ish, MD Member No.: 5,116 Region Association: North East States |
$ This happened to Nelson today while I was visiting: That's NOT your typical belt path or configuration! (IMG:style_emoticons/default/sad.gif) Tell me the valves are ok?! |
rick 918-S |
Nov 13 2010, 08:25 PM
$ This happened to Nelson today while I was visiting: That's NOT your typical belt path or configuration! (IMG:style_emoticons/default/sad.gif) Tell me the valves are ok?! Not a snowballs chance in hell my friend. |
Lennies914 |
Nov 13 2010, 08:37 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Ferg |
Nov 13 2010, 08:46 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
r_towle |
Nov 13 2010, 08:54 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
It may need a new head.
If you give up, let me know...I might be interested in buying it. Rich |
Series9 |
Nov 13 2010, 08:56 PM
$ This happened to Nelson today while I was visiting: That's NOT your typical belt path or configuration! (IMG:style_emoticons/default/sad.gif) Tell me the valves are ok?! Not a snowballs chance in hell my friend. The valves that were closed at the time are fine. |
jasons |
Nov 13 2010, 09:02 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
My S2 stripped the belt teeth on start up. I lost all 8 exhaust valves, no intake valves. That belt had around 40k on it. I also had the clutch fail. I wouldn't touch another one of those cars.
BTW one of my good friends is doing an LS1 conversion on an S. I am guessing he is well over $10k invested in just the swap by now. But he hasn't cut any corners either. |
Gint |
Nov 13 2010, 10:46 PM
Mike Ginter Group: Admin Posts: 16,076 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Yuk. I'd like to see pics though.
GaroldShaffer |
Nov 13 2010, 11:50 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
$ This happened to Nelson today while I was visiting: How many miles on that belt? When I had my 88 944 the belt was replaced every 30k and not 1 mile over that. Also pulled the cover and inspected and checked the belt tension to make sure things were good once a year. Due the proper maint work on a 944 / 968 and they will last a long time. I'm not saying this 968 wasn't maintained properly, stuff happens even when you do. Hopefully it's just bent valves. |
rfuerst911sc |
Nov 14 2010, 05:33 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I had a 1987 944S it was a nice car. Had all maint. up to date and the timing belt only had 15,000 miles on it when it snapped. Bent a bunch of valves so I sold it. I will never own another. It's a shame as they are nice handling cars with room in the back with the hatch but these engines should have had a timing chain or just gears.
ChrisFoley |
Nov 14 2010, 06:40 AM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Yuk. I'd like to see pics though. Rubbernecker. (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/biggrin.gif) |
jasons |
Nov 14 2010, 08:17 AM
Due the proper maint work on a 944 / 968 and they will last a long time. I'm not saying this 968 wasn't maintained properly, stuff happens even when you do. Hopefully it's just bent valves. I'm not going to disagree with you. But, a car that needs a timing belt every 30k and a $500+ tool to tension that belt is a fail. Its a shame because they got a lot right on those cars. They are still attractive cars (especially the 968), and they don't rust. Its the clutch or timing belt that puts them in the junkyard. |
Lo-Fi Version | Time is now: 29th May 2024 - 03:00 AM |
