To tear out the back firewall or not? Please help me decide, I think the rust may require it... |
ghuff |
Nov 16 2010, 02:56 PM
This is certainly not what I expected down here. Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
So I removed the back half of the wiring harness I peered into the area between the firewalls some. What I saw seemed to make me think if I do not cut access holes in the back firewall to fix what is starting, I may be putting a lot more work into this car in the future................
Pics: |
SirAndy |
Nov 16 2010, 03:01 PM
Resident German Group: Admin Posts: 41,673 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can't see any pics (IMG:style_emoticons/default/confused24.gif) but if you are talking about the double-walled lower portion of the firewall, it's MUCH easier to access if you simply remove the rear bottom part of the floor pan.
This will give you access to the *complete* double walled section and it's very easy to work in there that way, plus, you can close it all up easily by simply spot welding the floor-pan piece back on. IMHO, much easier than any "access hole" can ever be ... (IMG:style_emoticons/default/popcorn[1].gif) |
1968Cayman |
Nov 16 2010, 08:18 PM
Redacted by Irving Washington Group: Members Posts: 116 Joined: 5-February 10 From: Holly Springs, GA Member No.: 11,332 Region Association: South East States |
Wow. That's nasty. I'd tear it out just to make sure.
ghuff |
Nov 17 2010, 08:05 AM
Can't see any pics (IMG:style_emoticons/default/confused24.gif) but if you are talking about the double-walled lower portion of the firewall, it's MUCH easier to access if you simply remove the rear bottom part of the floor pan. This will give you access to the *complete* double walled section and it's very easy to work in there that way, plus, you can close it all up easily by simply spot welding the floor-pan piece back on. IMHO, much easier than any "access hole" can ever be ... (IMG:style_emoticons/default/popcorn[1].gif) I suck and did not paste the imageshack link then lost it. I will take another pic and post it after work when I am back home. Do I just sort of cut it where it meets the inner rear firewall that is in the cabin, and then spot it back up on both ends? |
SirAndy |
Nov 17 2010, 01:32 PM
Do I just sort of cut it where it meets the inner rear firewall that is in the cabin, and then spot it back up on both ends? Sort of. You should be able to drill out the spot welds on either side of the firewall and then cut the floor pan in a way that allows you to spot weld the floor piece back on later instead of having to do a butt-weld. I'm at work and don't have any pics right now ... (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 05:14 PM |
