tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
I am looking to buy a 914 engine case. I need a case that has not been line bored (and ideally doesn't need to be line bored). I am somewhat tight on funds (who isn't) so I need a case that is as close to ready to use as possible.
Please let me know if you have one that you would be willing to part with. Thanks |
OU8AVW |
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region ![]() |
What's your timing? I have two cases @ the machine shop getting cleaned and checked over. I will use the better of the two but the other will be professionally checked out and i expect just fine. It is a late model 2.0. I'll have a spare crank, rods, and pistons then too. Main problem is my machinist is slow......
Mike |
914LIVE |
Newbie ![]() Group: Members Posts: 10 Joined: 29-June 10 From: Portland, Oregon. Member No.: 11,890 Region Association: None ![]() |
I am looking to buy a 914 engine case. I need a case that has not been line bored (and ideally doesn't need to be line bored). I am somewhat tight on funds (who isn't) so I need a case that is as close to ready to use as possible. Please let me know if you have one that you would be willing to part with. Thanks ________________________________ PM sent. Two GC series cases available. Thank you, TOMAS. ________________________________ |
Lo-Fi Version | Time is now: 16th June 2024 - 06:38 PM |
