> rear trailing arm mount, how do i fix this
mrbubblehead
post Dec 27 2010, 02:46 PM
Twodollardoug
im totaly bummed out about this. after about 50 hours of research and electrical work on my new toy, i found this while hooking up my fuel line.
its really bad. to the point where i dont think its safe to drive the car.... (IMG:style_emoticons/default/headbang.gif)
do you guys think this is something i should try fix this myself and box it in? im not sure my fab skills are up to the task....
or should i leave this one up to the professionals? is there a shop in so cal. that is competent enough to fix this? forgive my noobieness for not knowing any shops around. i'm not out to insult anyone. i just dont want a hack job. i could do that myself. LOL
Replies(1 - 19)
mrbubblehead
post Dec 27 2010, 02:50 PM
Twodollardoug
heres another shot.
Tom_T
post Dec 27 2010, 03:00 PM
TMI....
Better check the other side too! (IMG:style_emoticons/default/dry.gif)
IMHO - get 1 or 2 new repro consoles from Restoration Design (see member vendors & banner ad) & replace one or both - don't try to patch those up, cuz they'll just continue to rust & fail later. IIRC - AA also sells them in repro form.
If not up to your skills, PM to Ed Arango in HB, or to Kevin/kconway in Long Beach about his guy referred to me below -
<snip>
Message Forwarded From kconway
Tom,
I received a call from Milt Becker this morning and he said he would be interested in speaking to you about your car and perhaps coming out to take a look. You can reach him at this number: 562-424-5943. Not sure of his schedule but if you leave a message he's sure to get back to you.
Good luck,
Kev
<end snip>
I think both guys can bring their eqpt. to your place to do the work, and Ed may be using the same guy. I haven't used either one yet, so ask them for referrals.
PS - no, definitely NOT safe to drive that way!
dr914@autoatlanta.com
post Dec 27 2010, 03:02 PM
don't be bummed! Happens all of the time. We have two cars in the shop right now that we are installing new ones. We manufacture the piece and sell it to all of the usual suspects, but you will need to drop the engine to install it. If you can weld you can install it. Do not drive the car though!!
QUOTE(mrbubblehead @ Dec 27 2010, 01:46 PM) *
Resident German
QUOTE(mrbubblehead @ Dec 27 2010, 12:46 PM) *
Not safe to drive!
The good news is, this is a pretty common failure.
Restoration Design makes a complete replacement piece:
http://www.restoration-design.com/
The bad news is, this is NOT a newbie job. You'll need someone experienced to fix this correctly.
The Slow-Cal guys should be able to point you to a good shop ... (IMG:style_emoticons/default/welder.gif)
mrbubblehead
post Dec 27 2010, 03:15 PM
Twodollardoug
QUOTE(SirAndy @ Dec 27 2010, 01:02 PM) *
Not safe to drive!
well i do have a mig welder, and a tig welder. and more time than money. my fear is not getting the alignment of the pivot correct. is ther a jig out there to use? i have converted swing arm vw's to irs in the past. my confidence level is going up. im going to have to fix it myself. im already starting on taking the engine out.
is there a thread or tutorial on the repair? i have searched but really havnt found anything.
JoeSharp
post Dec 27 2010, 04:09 PM
In Irvine, Ca. May 15-18
We have a friend in your neighborhood that can help you. He doesn't post here and I believe he lives in Yucaipa. PM me your phone number and I'll try to get you 2 together.
stugray
post Dec 27 2010, 04:15 PM
That looks very familiar:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1290372313.1.jpg)
http://www.914world.com/bbs2/index.php?sho...113186&st=0
I just finished fixing mine, but it was the drivers side.
I assume your is the passenger side.
The passenger side can be purchased new, but not the DS.
I welded the crack with a backup strip, then put the reinforcement plates from tangerine racing on BOTH sides.
THEN.... I will be putting the support in that braces the ears to the firewall.
Stu
mrbubblehead
post Dec 27 2010, 04:22 PM
Twodollardoug
wow, im not the only one with this problem. im going to check out your thread know. thank you. i googled 914 suspension console repair and got a bunch of hits. i helps to use the correct terminology.
post Dec 27 2010, 05:05 PM
Resident German
QUOTE(mrbubblehead @ Dec 27 2010, 02:22 PM) *
I used our search and typed in:
+suspension +console
and got hours worth of reading ... (IMG:style_emoticons/default/smile.gif)
sean_v8_914
post Dec 27 2010, 05:41 PM
Chingon 601
I have posted at least 3 of these repairs here and on club. the factory manual has teh measuring points explained in detail. I use 1/8 stainless wires cut to facory spec and measure as illustrated in teh manual. I have secrets to share but cant post them here..."they" are watching us"
I have done more than I remember now. please do not patch it. they are ALL rotten inside
sean_v8_914
post Dec 27 2010, 05:47 PM
Chingon 601
the driver side is not available and must be fabricated but it rarely fails. the battery above teh right side is teh main cause
sean_v8_914
post Dec 27 2010, 05:55 PM
Chingon 601
bvmncgh
sean_v8_914
post Dec 27 2010, 05:57 PM
Chingon 601
mn,
sean_v8_914
post Dec 27 2010, 05:58 PM
Chingon 601
whoever welds it up: be sure they passivate the rust before welding it up
mrbubblehead
post Dec 27 2010, 06:10 PM
Twodollardoug
thanks alot sean. a picture is worth 1000 words.
mrbubblehead
post Jan 6 2011, 10:38 PM
Twodollardoug
well, im doin it fellas. i replaced the rear console and welded it up today. this is my first time doing anything like this so take it easy on me.
Mike Bellis
post Jan 6 2011, 10:42 PM
Resident Electrician
Looks great! nice welds! (IMG:style_emoticons/default/first.gif)
silver74insocal
post Jan 6 2011, 10:46 PM
(IMG:style_emoticons/default/smilie_pokal.gif) looks pretty damned good to me..keep it up...
championgt1
post Jan 6 2011, 10:51 PM
Don't embarrass me Filmore!
Looks good!
- Lo-Fi Version Time is now: 2nd July 2025 - 07:48 PM
