914-6 oil line on bottom of tank, Possible to remove line without removing tank? |
mskala |
Dec 31 2010, 03:53 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
For the oil line coming out the bottom of the tank (not the side):
Seems like there is not much room under the tank, can you remove and replace the line with a crow's foot or something? |
GeorgeRud |
Dec 31 2010, 04:17 PM
I've always removed the tank, then removed the line. Take care to note the angle of the line fitting so it will reinstall correctly and obviously tighten before reinstalling the tank.
I imagine that there is probably some sort of wrench that may fit, but none of mine do. Removing the tank also gives you an opportunity to really clean back in that area (Road debris does get kicked up there while driving). |
Matt Romanowski |
Dec 31 2010, 05:01 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
I think Mark Nadler did this on Judy's car. You might want to ask him.
J P Stein |
Dec 31 2010, 06:16 PM
I've always removed the tank, then removed the line. Take care to note the angle of the line fitting so it will reinstall correctly and obviously tighten before reinstalling the tank. I imagine that there is probably some sort of wrench that may fit, but none of mine do. Removing the tank also gives you an opportunity to really clean back in that area (Road debris does get kicked up there while driving). (IMG:style_emoticons/default/agree.gif) Nuthin' in my tool box either. (IMG:style_emoticons/default/sad.gif) Getting the tank out & back in is an exercise in frustation to boot. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:48 PM |
