Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
Check out this cool video of a 908 engine on the engine dyno at Rothsport Racing in Tualatin. I had the privilege to not only see this engine during its assembly phase, but they recently had another 908 engine under assembly and on the dyno that I got to see at several phases of the rebuild. Those engines are remarkable in the engineering detail from that era. Every nut, bolt, and stud was titanium and the exhaust layout was impressive.
Welcome to Rothsport Racing - Engine Dyno Tuning - Porsche 908 Engine Question: What engine was behind the 908 engine in the factory 914/8 car? -Britain |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
No idea, but I recall hearing that they could dogear changes trackside...so it must have been a custom unit.
Any idea what the bore and stroke were? Rich |
Zimms |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,415 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest ![]() ![]() |
![]() This is a photo of the silver /8 from the museum. Maybe you can identify it from this? |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,908 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,011 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Jeeze! did you see that freakin dizzy! (IMG:style_emoticons/default/wacko.gif) Cool!
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,143 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Sheer music (IMG:style_emoticons/default/rock_band.gif)
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Question...what transmission went in the 914-8 car? According to DGVWPB the red 914-8 had a "914-6 style transmission which was re-geared and strengthened" ... The real kicker is the shift rod which goes from the shifter in a 90 degree angle towards the passenger side first, then in another 90 degree angle straight backwards under the passenger seat and then with another 90 degree angle into the bottom of the transmission! (IMG:style_emoticons/default/blink.gif) |
SirAndy |
Btw. DGVWPB also has dyno sheets and a acceleration diagram ... (IMG:style_emoticons/default/driving.gif)
The diagrams show the max. speed at 262 km/h in 5th gear at 8000 rpm. However, the redline was set for 8400 rpm and the motor is supposedly good for 10,000 rpm so in theory the car can go even faster than that. |
TC 914-8 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 833 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest ![]() ![]() |
I have a Porsche book that lists the 908 as the "Widow maker" Wayyy to much engine for the car.
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,859 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
No Such thing as too much motor, just not enough driver.
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
hike up your skirt Nancy!
"you have enough power when you can lay black skid marks from your last apex to the next turn in" too much power is like saying too much money |
TC 914-8 |
No Such thing as too much motor, just not enough driver. (IMG:style_emoticons/default/agree.gif) I'll dig up the book when I get home and scan some details (IMG:style_emoticons/default/popcorn[1].gif) |
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
The real kicker is the shift rod which goes from the shifter in a 90 degree angle towards the passenger side first, then in another 90 degree angle straight backwards under the passenger seat and then with another 90 degree angle into the bottom of the transmission! If that pic is correct the diff cover is on the correct side so the diff/ring can be removed and serviced without having to take the gear cluster out first (911-like). That sure makes for easier LSD clutch changes and diff/lash setup! That's true in our cars only if the trans is inverted. Then we have to put up with a steep CV/axle angle into the wheel hubs unless the car is lowered to about 1-2 inches above the ground. (IMG:style_emoticons/default/sawzall-smiley.gif) .... too much power? bwaaaahhhhhh! |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,585 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
Cool, that's the same type of unit that was in the red 914/8...i forgot the 908 had a cooling fan like that.
sean_v8_914 |
I know the book. "Scary Porsches by Nancy Fancypants"
How about Mark Donahue in that short tail 917 with 1400-1700hp on a dial? that is the souce of the above quote. It takes all types to make this world go 'round. some write books and some make the history for them to write about. "Scotty, I need more power, now!" |
Chris Pincetich |
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California ![]() |
3 years ago a 908 arrived at the PCA AX race I attended. It was a "shake-down" exercise 2 weeks before Monterey Historics. They paid several Benji's and were granted unlimited runs. I spent almost 20 minutes oogling over it during our lunch break
(IMG:style_emoticons/default/drooley.gif) It posted times 1-2 seconds faster than any other car. By the end of the day they were happy enough to adjust settings for faster AX times vs. track feel tuning. Then they got even faster. I think it was a 908/3 and know it was the one with Martini Racing stripes that took 2nd or 3rd overall at the Historics race that year. I want one! (IMG:style_emoticons/default/beerchug.gif) |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
3 years ago a 908 arrived at the PCA AX race I attended. It was a "shake-down" exercise 2 weeks before Monterey Historics. They paid several Benji's and were granted unlimited runs. I spent almost 20 minutes oogling over it during our lunch break (IMG:style_emoticons/default/drooley.gif) It posted times 1-2 seconds faster than any other car. By the end of the day they were happy enough to adjust settings for faster AX times vs. track feel tuning. Then they got even faster. I think it was a 908/3 and know it was the one with Martini Racing stripes that took 2nd or 3rd overall at the Historics race that year. I want one! (IMG:style_emoticons/default/beerchug.gif) This one? http://www.youtube.com/watch?v=wFcm4KUvQsg |
thelogo |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None ![]() |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
As I recall, and I could very well be wrong, the 908 had a tranny very similar in design to the "snail tranny" used in some 1979-1980 924s and 931s. The diff was behind the gear cluster instead of in front of it. Dennis Aase would know, he had one ...............
The Cap'n |
Lo-Fi Version | Time is now: 9th July 2025 - 01:31 PM |
