| gerziebaker |
Jan 10 2011, 12:37 PM
Newbie ![]() Group: Members Posts: 17 Joined: 28-April 05 From: Macon, GA Member No.: 3,999 |
My buddy's car just quit running. It's a 1974 1.8L. He said he only has 1 volt coming from the coil. When he disconnected the yellow wire going from the dual relay to the negative side of the coil the voltage is 12.7. Is this a bad dual relay?
| underthetire |
Jan 10 2011, 12:47 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Why would there be a wire from a relay to the - side of the coil? I don't know L jet but that doesn't sound right to me. Should only be points to -side, and tach wire to - side.
| Root_Werks |
Jan 10 2011, 12:50 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,913 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
L-Jet uses the neg side of the coil for triggering the fuel injectors. There are some good write-ups on testing the double relay, search for them. (IMG:style_emoticons/default/wink.gif)
| underthetire |
Jan 10 2011, 12:56 PM
L-Jet uses the neg side of the coil for triggering the fuel injectors. There are some good write-ups on testing the double relay, search for them. (IMG:style_emoticons/default/wink.gif) Ah, that makes sense then. |
| dr914@autoatlanta.com |
Jan 10 2011, 01:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Hopefully it was a white/beige wire.
| Cevan |
Jan 10 2011, 01:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
The dual relay gets power from the coil when the key in on or in the start position. This in turns trips one side of the relay and powers the ECU, the resistors, and the AFM.
When the key is in the starting position, the other half of the relay gets power through the terminal at the starter. This trips the second relay and power goes to the AAR and the fuel pump. Once the engine is running, the AFM flaps stays open, letting power go to the second half of the relay and powering the AAR and fuel pump. |
| jim_hoyland |
Jan 10 2011, 04:05 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,033 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
The yellow wire from the dual relay should not be going to the coil if it has the original wiring.... There is a series (3) tests you can do to verify a dual relay works properly. It only requires a 9 volt battery and two leads. Shoot me an email with your email address and I can send you a copy--it's in excel.
| r_towle |
Jan 10 2011, 08:09 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
| jim_hoyland |
Jan 10 2011, 09:37 PM
See pic:
Lo-Fi Version | Time is now: 12th March 2026 - 07:26 PM |
