Lincoln pack100 Welding?, What wire/settings works best with our cars? |
Jeffs9146 |
Jan 10 2011, 03:55 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Lennies914 and I are welding up some AC holes the PO put all over my car and we are having a problem with blow through. We currently have it set at A 1.4 with flux core .035 #2 wire!
Lennie is almost to Harbor freight and wants to know what is the best used with our cars?? Thanks for any quick replies!! (IMG:style_emoticons/default/piratenanner.gif) |
underthetire |
Jan 10 2011, 03:58 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Lennies914 and I are welding up some AC holes the PO put all over my car and we are having a problem with blow through. We currently have it set at A 1.4 with flux core .035 #2 wire! Lennie is almost to Harbor freight and wants to know what is the best used with our cars?? Thanks for any quick replies!! (IMG:style_emoticons/default/piratenanner.gif) Have him pick up a reg set and my bottle. That will help a bunch ! |
underthetire |
Jan 10 2011, 03:59 PM
Shoot, i need a desk magnifying lamp they have....
Jeffs9146 |
Jan 10 2011, 04:00 PM
He is doing that but we are out of wire so he needs to know what to get in both Flux and solid!
underthetire |
Jan 10 2011, 04:05 PM
better stick with the .035, otherwise he will be looking for tips to.
Jeffs9146 |
Jan 10 2011, 04:12 PM
I just hung up the phone with him and he will get you your magnifying light if you call him and tell him what you need ASAP!
He is planning on getting wire, tips & Regulator! We just need to know what is the best wire to use on our cars, we think the metal is 22g so if everything is ideal what wire is best? |
underthetire |
Jan 10 2011, 04:21 PM
I just hung up the phone with him and he will get you your magnifying light if you call him and tell him what you need ASAP! He is planning on getting wire, tips & Regulator! We just need to know what is the best wire to use on our cars, we think the metal is 22g so if everything is ideal what wire is best? Don't have his number with me, it doesn't matter. I need to make a trip over there anyway to get the bike hanging kit as well. Guess he'll be picking up my bottle tonight? |
Jeffs9146 |
Jan 10 2011, 04:27 PM
Call him at 1-###-###-####
underthetire |
Jan 10 2011, 04:29 PM
Got it, now take his number off there !
Jeffs9146 |
Jan 10 2011, 05:19 PM
I did ask him!! (IMG:style_emoticons/default/beerchug.gif)
Andyrew |
Jan 10 2011, 06:05 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
I like .30 for stuff under 1/8" thick..
mrbubblehead |
Jan 10 2011, 06:44 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i use .023 wire on sheet metal. 75/25 gas. 15 psi for flow. the trick is to cut your nozzel back so it is flush with your tip.
two-strokejohn |
Jan 10 2011, 06:55 PM
Member Group: Members Posts: 81 Joined: 30-March 06 From: Orient, Ohio Member No.: 5,793 Region Association: North East States |
Home Depot carries the Lincoln line of wire and tips etc. I use the .025 ER70S-6 super L-56 wire for thin sheet metal with the argon /co2 mix for gas. The flux wire doesn't seem to be consistent and makes a mess with the flux. Rmember: metal must be clean, clean, clean. Good luck.
ONTHEGRIND |
Jan 10 2011, 07:03 PM
Member Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None |
I use .023 gas 30 is the lowest for flux i belive..
strawman |
Jan 10 2011, 07:14 PM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
I have found ESAB Easy-Grind 0.23" wire and 75/25 gas to be the best. As mentioned above, the metal has to be uber-clean, too. Can't say which settings, since I don't have the same MIG welder that you have...
Where ever possible, also put a heat sink behind the weld. HF has a brass spoon that works pretty well. And weld in short bursts to keep from warping the metal and to avoid heat gain that can lead to blow-through. Geoff |
mrbubblehead |
Jan 10 2011, 07:17 PM
I have found ESAB Easy-Grind 0.23" wire and 75/25 gas to be the best. As mentioned above, the metal has to be uber-clean, too. Can't say which settings, since I don't have the same MIG welder that you have... Where ever possible, also put a heat sink behind the weld. HF has a brass spoon that works pretty well. And weld in short bursts to keep from warping the metal and to avoid heat gain that can lead to blow-through. Geoff |
r_towle |
Jan 10 2011, 08:05 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
30 is the smallest for the flux core.
One step from the bottom on power. Bottom on amps. Hold the handle back farther from the metal...its another way to regulate the heat...closer you are, hotter it gets...pull back almost an inch and you can weld very thin metal. Rich |
Jeffs9146 |
Jan 10 2011, 09:46 PM
Thanks all!
Lennie got here today and we had an issue with the "upgrade" kit the guy sold him for the gas. It blew the solinoid as soon as the trigger was pressed. I guess he sold him the kit for the 125 instead of the 100! Now we are on hold until we get the right parts! Lennie decided on purchasing both the .023 and the .031 for thicker pieces so we are set once we get the gas solinoid replaced! |
underthetire |
Jan 10 2011, 10:07 PM
Thanks all! Lennie got here today and we had an issue with the "upgrade" kit the guy sold him for the gas. It blew the solinoid as soon as the trigger was pressed. I guess he sold him the kit for the 125 instead of the 100! Now we are on hold until we get the right parts! Lennie decided on purchasing both the .023 and the .031 for thicker pieces so we are set once we get the gas solinoid replaced! Those solenoids have flow direction on them sometimes. The pressure helps them seat until energized, if backwards the pressure can pull them off the seat and leak out. Just something to check. And the voltage to the coil obviously. |
Jeffs9146 |
Jan 11 2011, 11:03 AM
The gas was not hooked up when it blew so even if the direction was wrong it shouldn't have been a problem.
We think the one that they sold him was for a welder that has a step down transformer to use 12v solinoids where the pak 100 uses a 120v solinoid! |
Lo-Fi Version | Time is now: 8th June 2024 - 04:32 AM |
