dashboard switches |
Stephane |
Apr 26 2004, 04:51 PM
Newbie Group: Members Posts: 45 Joined: 13-February 04 From: New Brunswick, Canada Member No.: 1,653 |
How do I safely remove those switches from the dash? any tricks or what special tools do I need?
Stephane (IMG:style_emoticons/default/smash.gif) |
Mark Henry |
Apr 26 2004, 04:55 PM
The knobs you just unscrew.
There is a special tool for the retainer nut but needle nose pliers will work. |
Brad Roberts |
Apr 27 2004, 01:11 AM
Stephane,
Did you figure this out ? I can post pics for you if need be. B |
4WheelDrifter |
Apr 27 2004, 08:30 AM
Having a mid-life crisis @ 35 Group: Benefactors Posts: 201 Joined: 15-April 04 From: Bethel, CT Member No.: 1,934 |
I'm wondering if meant how to get them out from the back also. It's not easy from the quick look I took.
Gint |
Apr 27 2004, 06:39 PM
Mike Ginter Group: Admin Posts: 16,076 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I I haven't already said it, welcome to the club!
Is Stephane like Stephan or Stephanie? |
dmenche914 |
Apr 27 2004, 08:13 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Disconnect your battery before starting!!! (else you could end up ruining a very very expensive wire harness)
After the knobs are unscrewed, the aluminum bezel that is basically a nut holding the switch can be worked free with a needle pliers, stubborn bezels can be lossened by reaching behind to the switch, and twisting it (it has better leverage than the bezel) If you are pulling all the stuff from the dash, get the instrument pod (all three main gages) out first, that will allow you to reach in from above to the switches, this will help with access if you need more room. good luck, dave |
jfort |
Apr 28 2004, 12:41 PM
Senior Member Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
nobody said to unscrew and lower the fuse block, or was that assumed?
Lo-Fi Version | Time is now: 29th May 2024 - 02:30 AM |
