KYB rear shocks models, Difference between W0133-1611933 and KYKG9003 |
Valy |
Feb 7 2011, 12:18 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I've seen 2 different models of KYB rear shocks: W0133-1611933 and KYKG9003.
I'm not sure if those are really different or just the same with different part numbers. (IMG:style_emoticons/default/confused24.gif) Does anyone know the difference? Also, should I bother with KYB (since I'm cheap and have them in front) or pass and pay a bit more for the Bilstein? I have no rear torsion bar so I've seen some comments that the hard KYB might help in the rear, is this correct? Thanks. |
carr914 |
Feb 7 2011, 12:32 PM
Racer from Birth Group: Members Posts: 118,970 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
KYBs are Junk - if you saw them side by side with a Koni or Bilstein, you would never put them on a car
Eric_Shea |
Feb 7 2011, 12:45 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
The W0133-1611933 models suck just slightly less than the extremely shitty KYKG9003 models. (IMG:style_emoticons/default/biggrin.gif)
Always go with the best shock you can afford on these little beasts. It will literally be a night and day difference in your handling. Bilsteins are excellent shocks. |
bandjoey |
Feb 7 2011, 09:12 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Bilsteins.. You'll be super happy. parts geek.com $106 each on rears.
Lo-Fi Version | Time is now: 7th June 2024 - 02:19 AM |
