blinking brake light, help |
tomh |
Feb 10 2011, 12:30 AM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
I just reinstalled my rear calipers after being off the last 2 weeks wile my bearings were being changed.I bled them several times and reset the master cylinder button and the blinking light still will not go out.I even unplugged the wire a few times and also checked the e-brake switch.I am using one of those one person bleed it your self cups and it feels like the brakes are nice and hard.
Should I be bleeding the fronts also or is their any other tricks? I got to get this thing off jack stands! Thanks |
tomh |
Feb 10 2011, 12:44 AM
Ok so I started the car up this time and then the light went off.
If any one can explain why it would be helpful. |
McMark |
Feb 10 2011, 08:33 AM
Check for continuity at the MC switch with the wires unplugged.
Check the wiring for good ground on one side and good wire to the interior. Check the wiring at the e-brake switch to make sure it's got good wire to the flasher. Electrical troubleshooting is all about being thorough. Gotta CONFIRM every aspect until you find one that's wrong. |
Lo-Fi Version | Time is now: 8th June 2024 - 11:24 PM |
