Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
A&PGirl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None ![]() |
PET 402-00 Pos. 34
Qty. 2 Special thrust washer for the front suspension. This goes under the nut that you have break loose when you remove the brake rotor or do any suspension work. It is cad/yellow plated. Appears to be available through Aircooled Volkswagen shops. ![]() |
Lo-Fi Version | Time is now: 11th July 2025 - 07:01 AM |
