> CHT sensor install, Made a tool
rwilner
post Mar 3 2011, 08:39 PM
No Ghosts in the Machine
In case anyone has to replace their CHT sensor which is a PITA, you'll have to make some type of tool. I ground down a corner off a 3" extension, and attached a deep socket.
It's much easier to install and uninstall if you remove the decel valve and MPS.
Here's a picture of the extension and socket with the CHT ready to install. I attached the washer to the CHT sensor with a drop of superglue:
Replies(1 - 14)
nowlings
post Mar 3 2011, 08:44 PM
QUOTE(rwilner @ Mar 3 2011, 06:39 PM) *
That is Slick! It's amazing, I never thought about grinding the corner of the extension. I've alway fenagled it by just using the deep well socket and using the wire with tension to guide the sensor to the hole. you have a cool tool there and now I'm going to make mine. I don't know about you, but I find myself replacing that sensor every couple of years.
oldschool
post Mar 3 2011, 08:50 PM
How do you know you need to replace the cht (IMG:style_emoticons/default/confused24.gif)
rwilner
post Mar 3 2011, 08:58 PM
QUOTE(oldschool @ Mar 3 2011, 09:50 PM) *
The PO soldered a 1/8w resistor to the old one, and the vibration caused it to snap. I had a NOS one from mark heard so I put that one in place of the old one instead of repairing the wire.
rwilner
post Mar 3 2011, 09:00 PM
QUOTE(nowlings @ Mar 3 2011, 09:44 PM) *
man I hope I don't have to do that -- the 017 part is a pretty rare beast for the 73 2.0L.
saigon71
post Mar 3 2011, 09:37 PM
Nice tool! What size is that socket? I will be crafting one up myself. Not to hijack, but I suspect I need a new CHT for my 1974 D-Jet and found these on Ebay. Price seems very reasonable. Are these legit?
http://cgi.ebay.com/ebaymotors/Porsche-914...sQ5fAccessories
luskesq
post Mar 3 2011, 10:55 PM
QUOTE(saigon71 @ Mar 3 2011, 07:37 PM) *
I believe 13 mm. When I did mine I took a cutting wheel and cut a groove wide enough for the wire to pass through into the corner of a 3" cheapie extension. That way it doesn't weaken the entire corner of the extension (although the're inexpensive) to much.
Keith
jimkelly
post Mar 4 2011, 07:02 AM
Delaware USA
i added this invention to this thread...
Home made tools, Show us yours
http://www.914world.com/bbs2/index.php?showtopic=91491<br />
rwilner
post Mar 4 2011, 04:02 PM
QUOTE(saigon71 @ Mar 3 2011, 10:37 PM) *
It's a 13mm deep craftsman socket with a 3" extension from lowes.
Mark Heard has some (914sixer), and he is legit. Send him a PM and he'll hook you up.
rwilner
post Mar 4 2011, 04:03 PM
QUOTE(jimkelly @ Mar 4 2011, 08:02 AM) *
i added this invetion to this thread...
thanks Jim, great thread!
Markl
post Mar 4 2011, 10:04 PM
A 1/2" plumber's faucet wrench works fine - a couple of bucks at Ace. No grinding, no welding. Can also be used to tighten faucet valves.
rd914
post Aug 30 2011, 02:48 PM
QUOTE(Markl @ Mar 4 2011, 09:04 PM) *
Can you post a pic of what it look like? Thanks.
TheCabinetmaker
post Aug 30 2011, 04:05 PM
I drive my car everyday
Or,....... you could just stuff the wire in the deep socket and go.
r_towle
post Aug 30 2011, 08:26 PM
Custom Member
QUOTE(vsg914 @ Aug 30 2011, 06:05 PM) *
Zactly
rwilner
post Sep 1 2011, 11:53 AM
QUOTE(r_towle @ Aug 30 2011, 10:26 PM) *
Zactly
but then you don't get to grind anything
- Lo-Fi Version Time is now: 22nd October 2026 - 09:33 PM
