Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,815 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Its flaking off and the red plastic underneath is revealing itself. At first glance it looks like red over spray. I can't get a photo now they are in my attic. Is this common? Time to replace or can the be painted/plated?
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
pretty typical Andy.
look like this? I used Aluminum Foil Tape on mine and it worked well. Other folks spray them with Chrome paint etc... Attached image(s) ![]() ![]() ![]() |
Krieger |
Dan, that cannot be to code! Very nice.
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,917 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
I painted mine with the 'chrome' spray paint (to code) (IMG:style_emoticons/default/laugh.gif)
![]() ![]() ... never dawned on me to use foil tape (IMG:style_emoticons/default/idea.gif) ... good idea. |
avidfanjpl |
914 Hemophiliac ![]() ![]() ![]() Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region ![]() |
From my scale modeling days, I can tell you that there is a product that helps make metal sheets adhere to plastic. It has been 25 years, but I used it to apply metal sheets, very thin, to plastic planes to make them look like aluminum and other metals.
I can't remember the name, but others may know of it. John |
Krieger |
From my scale modeling days, I can tell you that there is a product that helps make metal sheets adhere to plastic. It has been 25 years, but I used it to apply metal sheets, very thin, to plastic planes to make them look like aluminum and other metals. John Its probably illegal now or banned in CA....the fumes you know (IMG:style_emoticons/default/smoke.gif) |
DanT |
roll of aluminum foil tape was about $5. No toxic fumes and took about 1/2 hour to apply to both sides.
And it is definitely more reflective than the old silver paint/red plastic (IMG:style_emoticons/default/smile.gif) here is a pic of just the running lights after redoing with aluminum foil tape...brake lights are much brighter (IMG:style_emoticons/default/smile.gif) Attached image(s) ![]() |
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
Euro 911, when you painted yours did you drill out the rivets and pull it off and paint it? Or just tape it off and spray?
Just curious. I thought about pulling mine off and checking with some past colleagues and seeing if they can vacuum new foil on it. Not sure how it would look or turn out... |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
From my scale modeling days, I can tell you that there is a product that helps make metal sheets adhere to plastic. It has been 25 years, but I used it to apply metal sheets, very thin, to plastic planes to make them look like aluminum and other metals. I can't remember the name, but others may know of it. John John, Are you thinking of Bare Metal Foil? I am familiar with the name, but I have no experience with using it. I don't know how well it would hold up if applied inside the light fixture housings which are exposed to high and low temperatures and moisture, unlike the environments most model cars and airplanes are stored in. Having said that, the chrome bare metal foil has a pretty good chrome-like appearance which should be quite reflective. (IMG:style_emoticons/default/idea.gif) http://www.bare-metal.com/bare-metal-foil.html |
Krieger |
Wow Dan thats friggin bright. Tape it is.
euro911 |
Euro 911, when you painted yours did you drill out the rivets and pull it off and paint it? Or just tape it off and spray?... I don't remember removing any rivets, I think it just came apart with one screw or bolt ... did it back in 2007.The pic of mine may not look as bright as Dan's for a couple of reasons ... could be ambient light, or maybe someone's standing on the brake pedal? (IMG:style_emoticons/default/unsure.gif) ... they're definately much brighter than they were when I got the car. I think the tape might hold it's brilliance for a longer period of time than chrome paint would. Either method will yield better results than doing nothing (IMG:style_emoticons/default/shades.gif) |
AndyB |
The Governor is watching me ![]() ![]() ![]() Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States ![]() |
No DanT has the 3rd Brake light you would know if he was stepping on it trust me
DanT |
definitely the pic above of my car was just the running lights...
here it is with brake applied (IMG:style_emoticons/default/biggrin.gif) Attached image(s) ![]() ![]() |
Lo-Fi Version | Time is now: 31st July 2025 - 05:38 PM |
