What the heck is this little plug, laying on top of the transmission? |
tomeric914 |
Mar 20 2011, 10:36 AM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Working on the /6 conversion last night and just happen to look at top of the transmission and see this little plug sitting there next to a similar size hole. My first reaction was one of "WTF is this?" My second was, "How long has that that little plug been there and how have I not lost it?"
Anybody have a clue what this is and how it popped out? I could stick it back in but it'll probably just pop out again. Probably better to tap and plug it. |
windforfun |
Mar 20 2011, 10:52 AM
Senior Member Group: Members Posts: 1,835 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Breather port?
tomeric914 |
Mar 20 2011, 10:54 AM
Dr Evil |
Mar 20 2011, 10:57 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Clean it and the hole up and maybe it will be more clear. |
tomeric914 |
Mar 20 2011, 11:50 AM
Ok, now cleaned up and a few more views. The "plug" isn't a tight fit in the hole but definitely looks like it came from there.
The hole appears to be counterbored like a plug was supposed to go in there. Maybe there's supposed to be a pin or spring in that bore? Here's a few more shots. One backed up so you can see where it is on the case. |
IronHillRestorations |
Mar 20 2011, 12:01 PM
I. I. R. C. Group: Members Posts: 6,729 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Looks like PO mistake to me.
Cupomeat |
Mar 20 2011, 12:07 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
VEDDY EEENTERESTING TOM!
Does that intermediate plate look like aluminum? Or Magnesium... My first thought was that it was drilled for trans cooling/recirculating/spraying of oil, but that seems like an unusual place, unless it hits directly over the input shaft bearing. |
underthetire |
Mar 20 2011, 12:09 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Looks like a cross drill hole for something internal, factory probably plugged it. Pretty common on castings of all sorts, like the oil galley plugs.
Dr Evil |
Mar 20 2011, 12:39 PM
Looks like a mistake (IMG:style_emoticons/default/confused24.gif) Never seen one of those.
jmill |
Mar 20 2011, 01:21 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Maybe it's just trying to make a statement?
Attached image(s) |
KELTY360 |
Mar 20 2011, 01:33 PM
914 Neferati Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
That's where the little people leave their home on the way to tend their rust farms. (IMG:style_emoticons/default/shades.gif)
tomeric914 |
Mar 20 2011, 02:55 PM
Mar 21 2011, 08:02 AM
There is/was a aftermarket intermediate plate.
flipb |
Mar 21 2011, 08:10 AM
Senior Member Group: Members Posts: 1,728 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
That's where the little people leave their home on the way to tend their rust farms. (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/av-943.gif) |
r_towle |
Mar 21 2011, 09:31 AM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Probably a mistake that he plugged and the internal pressure was enough to pop that plug.
JB Weld Rich |
tomeric914 |
Mar 21 2011, 01:43 PM
Probably a mistake that he plugged and the internal pressure was enough to pop that plug. JB Weld Yea, it is interesting because the hole is neat and clean, not like someone drilled it (at least not half assed) and there's a step to it. A PO drill job would have gone right through without stopping, I would think. I was able to get enough purchase with a 6mm tap to thread the hole. I'll use a threaded plug with loctite to seal it up. I also checked the main breather and it was clear. |
Lo-Fi Version | Time is now: 7th June 2024 - 05:35 PM |
