oil pressure gauge, remote install |
minnesota loon |
Apr 4 2011, 05:20 PM
Member Group: Members Posts: 111 Joined: 30-September 07 From: white bear lake mn. Member No.: 8,173 |
What is the thread size in the engine where the sender installs npt1/8 or10-1 metric?
The gauge I have is 10-1 metric threads. I'm trying to make a remote with a greese gun hose npt1/8 and a npt1/8 female to female connector. The threads seem to be close but the 10-1 metric only screws on a few turns before it gets tight. Is this ok any help or thoughts. Do I need other adapters? |
type47 |
Apr 4 2011, 08:11 PM
What is the thread size in the engine where the sender installs npt1/8 or10-1 metric? The gauge I have is 10-1 metric threads. I'm trying to make a remote with a greese gun hose npt1/8 and a npt1/8 female to female connector. The threads seem to be close but the 10-1 metric only screws on a few turns before it gets tight. Is this ok any help or thoughts. Do I need other adapters? It's metric and I don't understand why people try to put an SAE hose in, although I don't know where to get a 10mm hose. 10mm...same as stock sender. |
Cap'n Krusty |
Apr 4 2011, 09:40 PM
Yes, it's metric, but it's TAPERED metric. The oil pressure senders we can get are 1/8 pipe, which is so close to 10mm fine tapered that the difference just doesn't matter. THAT'S why we use 1/8 tapered hose.
The Cap'n |
Lo-Fi Version | Time is now: 1st June 2024 - 06:43 PM |
