Clutch dragging when hot, Throw out the culprit? |
aircooledboy |
Apr 7 2011, 02:19 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
Hey boys,
Anything interesting going on here lately? (IMG:style_emoticons/default/stirthepot.gif) Oldest kid got her license today (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/barf.gif) , which through a series of comical complications required me to unexpectedly need to drive the 914 so she could use my car today. While it was great to get the old girl out for the 1st time of the year, I was reminded that when I put her away last year, I noticed a problem might be starting. When I 1st start out for a drive, it shifts great. by the time I get to the office and the car is good and warmed up, when I put the clutch in, I can feel it not quite completely releasing. Sitting at a stop, in gear, clutch in, I can feel it dragging a bit, car "grumbling" a little as I sit. When it did this at the end of last season, I tightened up the cable a little, but no change. I checked the clutch tube, and it's still solid and stationary at both ends. I'm thinking throw out bearing, but my time is so limited the days, I don't have the luxury of not getting it right on my first repair attempt. I doubt my initial diagnosis because I don't hear anything when I step on the clutch, and I've alway been able to hear a bad throw out before I've felt it. Any ideas? |
r_towle |
Apr 7 2011, 04:12 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
could be the little bushing behind the throw out rod fork is gonzo so you are not getting enough pull.
Could be throw out bearing Could be time for a clutch or pressure plate.. Pilot bearing is siezed? If you dont like doing it..do it all at the same time.. Good for another long run...depending upon how hard you drive it. You can pull the tranny and leave the motor in the car. Rich |
aircooledboy |
Apr 7 2011, 05:01 PM
could be the little bushing behind the throw out rod fork is gonzo so you are not getting enough pull. Could be throw out bearing Could be time for a clutch or pressure plate.. Pilot bearing is siezed? If you dont like doing it..do it all at the same time.. Good for another long run...depending upon how hard you drive it. You can pull the tranny and leave the motor in the car. Rich I don't think it could be that fork bushing because it's shifts great when cold. I don't think that would be temp sensitive. Pressure plate and disk are both pretty low milage (5000ish miles, high quality KEP stuff) I think I reused the pilot and throw out bearings, since they were reasonably new at the time and $ was tight, but I can't remember (was in '09). (IMG:style_emoticons/default/confused24.gif) So Rich, you think the pilot or throw out are pretty good possibilities? |
SLITS |
Apr 7 2011, 05:29 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Unless the throw-out bearing welded itself to the pressure plate fingers & pilot shaft, I wouldn't think so.
Pilot bearing seizure could/would keep the main shaft turning. Don't worry, it will disintegrate and the problem will stop, but then you might get a front tranny seal leak as the pilot shaft will wobble around. Oh, other than that ... no/low oil in the tranny. Just my opinions |
Dr Evil |
Apr 7 2011, 05:46 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Agree with SLITS. (IMG:style_emoticons/default/agree.gif)
ax914 |
Apr 8 2011, 06:01 AM
Newbie Group: Members Posts: 1 Joined: 28-March 10 From: sc Member No.: 11,516 Region Association: None |
I would try tightening the cable a touch more as it heats up it expands. It could be that the cable may be fraying and when you do tighten it it may break but then you will know. (IMG:style_emoticons/default/w00t.gif)
SUNAB914 |
Apr 8 2011, 08:47 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
You say the clutch and pressure plate are new, but what about flywheel? Make sure your fork isn't bent either.
sixnotfour |
Apr 8 2011, 12:32 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
the center of the tube could be broke loose, If the flywheel was resurfaced , did the pivot get a shim ?
aircooledboy |
Apr 8 2011, 03:23 PM
Fly wheel is original, so no shims, and clutch cable tube is solid in the middle too (the access hole in the tunnel is still open from when PO fixed it (IMG:style_emoticons/default/sawzall-smiley.gif) )
Slits and the Doc's opinion that it's more likely pilot bearing make pretty good sense after thinking it through. (IMG:style_emoticons/default/beerchug.gif) Guess I better order one up from Renegade. Since I'm always trying to learn something from my little fiascos: (IMG:style_emoticons/default/idea.gif) Slits, how could low trans oil be a factor? If the clutch is in, disk is free, so trans isn't turning. How would low oil result in that feeling like the clutch isn't fully released? |
SLITS |
Apr 8 2011, 03:52 PM
Fly wheel is original, so no shims, and clutch cable tube is solid in the middle too (the access hole in the tunnel is still open from when PO fixed it (IMG:style_emoticons/default/sawzall-smiley.gif) ) Slits and the Doc's opinion that it's more likely pilot bearing make pretty good sense after thinking it through. (IMG:style_emoticons/default/beerchug.gif) Guess I better order one up from Renegade. Since I'm always trying to learn something from my little fiascos: (IMG:style_emoticons/default/idea.gif) Slits, how could low trans oil be a factor? If the clutch is in, disk is free, so trans isn't turning. How would low oil result in that feeling like the clutch isn't fully released? Lo oil ... box gets really hot ... won't shift due to expansion and crap starting to weld together ... yes, they can get that hot. Renegade for a pilot bearing? Try our normal parts houses first .. GPR, Pelican, etc., If it's a V8 conversion ANY domestic iron parts house. |
aircooledboy |
May 5 2011, 07:42 PM
After a few tweaks with no success I'm pretty sure it's probably the pilot bearing.
Slits, this is the v8 I'm talking about. Are you saying a standard 350 bearing will work. I just assumed the ID would be different. Renagade wants 75 bones for one. (IMG:style_emoticons/default/blink.gif) I'm ok with them making a profit but im thinking theyre gonna have to buy me dinner before they get me to do that. If I can use a standard SBC bearing, that would be nice. Why yes, I am a very cheap bastard. Why do you ask? |
Lo-Fi Version | Time is now: 11th June 2024 - 05:25 PM |
