Correct orientation of pistons in calipers??, for front /4 calipers |
Mueller |
May 5 2004, 09:50 PM
Should the "D" shaped surface of the piston top face a certian direction???
Dave_Darling |
May 5 2004, 10:06 PM
Check the Haynes. There's a triangular shim that goes in there to keep the piston from rotating, the edge has a specific angle. It's to keep the pads from getting taper wear.
--DD |
Lo-Fi Version | Time is now: 10th June 2024 - 01:45 PM |
