Rear 5 Lug Conversion, Any "How To's" |
EdArango |
Apr 20 2011, 04:39 PM
914 Enthusiast Group: Members Posts: 267 Joined: 30-January 10 From: Huntington Beach, CA Member No.: 11,309 Region Association: Southern California |
Hello Everyone,
I just ordered the rear 5 lug conversion kit from Parts Heaven and I need a little help. I can't seem to find a tread that shows me how to replace parts out including the bearings. Can you guys give me a hand with links to these types of threads? Thank you my all knowing....all mighty..914 friends!! (IMG:style_emoticons/default/beerchug.gif) Ed |
PeeGreen 914 |
Apr 20 2011, 04:52 PM
Hello Everyone, I just ordered the rear 5 lug conversion kit from Parts Heaven and I need a little help. I can't seem to find a tread that shows me how to replace parts out including the bearings. Can you guys give me a hand with links to these types of threads? Thank you my all knowing....all mighty..914 friends!! (IMG:style_emoticons/default/beerchug.gif) Ed What does this "kit" include? There is a number of way you can covert. I will see if I can dig up the all inclusive 5-lug thread. |
PeeGreen 914 |
Apr 20 2011, 04:59 PM
EdArango |
Apr 20 2011, 05:12 PM
Thanks Jon for the link! This is what the kit come with. Ed |
PeeGreen 914 |
Apr 20 2011, 05:15 PM
Oh, that's pretty basic to do. You need a bearing press though.
Get the old bearings out and pull the new bearing in. Bolt the other stuff up and you are good to go (IMG:style_emoticons/default/beerchug.gif) |
mepstein |
Apr 20 2011, 05:20 PM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Ed- Read Eric's thread. He convinced me that I should switch to early 911 hubs, stub axles and cv's to take advantage of the stronger cv's when using a larger 6 engine. It's not something that you HAVE to do but you might want to. The same reason Dr Evil deleted 1st gear from my trans and added a flipped H for 5th gear. I wanted to have a reliable car so I'm trying to do things in advance to hopefully increse the reliability, longevity and drivability of the conversion. Everything about a big 6 conversion is a slippery slope to a big $ build.
913B |
Apr 20 2011, 09:35 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Read and buy this stuff from the hardware store, less than $15, pulled them old bearings out and installed the new ones like a breeze.
http://www.914world.com/bbs2/index.php?sho...91491&st=60 Post #73 and the link to the original post http://www.914world.com/bbs2/index.php?sho...rkona&st=40 As far as the removing the original flange (hub) goes, the trick is to to use an inverted ~20 mm impact socket with a long 1/2" extension and whack it from the inside out with a big hammer, came out like a breeze too, wouldn't hurt to spray some PB blaster between the hub and bearing. I can snap a pic to show what I mean tomorrow. Ed, can I ask a favor. I am having a heck of time locating machinist to drill my 4-lug rotors to 5. I was thinking of just buying 914-6 rotors. But some people say I need to turn them down. Can you sized up your 5-lug rotor and compare it to your orignal 4 lug rotor and tell me if the diameter and anything else is the same or different. Thanks in Advance Ted |
r_towle |
Apr 21 2011, 08:25 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Read and buy this stuff from the hardware store, less than $15, pulled them old bearings out and installed the new ones like a breeze. http://www.914world.com/bbs2/index.php?sho...91491&st=60 Post #73 and the link to the original post http://www.914world.com/bbs2/index.php?sho...rkona&st=40 As far as the removing the original flange (hub) goes, the trick is to to use an inverted ~20 mm impact socket with a long 1/2" extension and whack it from the inside out with a big hammer, came out like a breeze too, wouldn't hurt to spray some PB blaster between the hub and bearing. I can snap a pic to show what I mean tomorrow. Ed, can I ask a favor. I am having a heck of time locating machinist to drill my 4-lug rotors to 5. I was thinking of just buying 914-6 rotors. But some people say I need to turn them down. Can you sized up your 5-lug rotor and compare it to your orignal 4 lug rotor and tell me if the diameter and anything else is the same or different. Thanks in Advance Ted Ted, Call Rich Bontempi at HPH (High Performance House) I am certain he can help or point you at the right shop to get it done. RIch |
Eric_Shea |
Apr 21 2011, 08:58 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
All 914-6 rotors need be turned down. More money.
Ted, it's not that difficult: http://www.google.com/search?q=San+Mateo+A...amp;ie=&oe= Find a good automotive machine shop and tell them you want 5x130 instead of 4x130 Ed, if you're moving to a six, I'd recommend different but, I think we went through that... (IMG:style_emoticons/default/wink.gif) Depending on your rear calipers, those #18 rotors need to be machined as well. |
EdArango |
Apr 21 2011, 05:03 PM
Read and buy this stuff from the hardware store, less than $15, pulled them old bearings out and installed the new ones like a breeze. http://www.914world.com/bbs2/index.php?sho...91491&st=60 Post #73 and the link to the original post http://www.914world.com/bbs2/index.php?sho...rkona&st=40 As far as the removing the original flange (hub) goes, the trick is to to use an inverted ~20 mm impact socket with a long 1/2" extension and whack it from the inside out with a big hammer, came out like a breeze too, wouldn't hurt to spray some PB blaster between the hub and bearing. I can snap a pic to show what I mean tomorrow. Ed, can I ask a favor. I am having a heck of time locating machinist to drill my 4-lug rotors to 5. I was thinking of just buying 914-6 rotors. But some people say I need to turn them down. Can you sized up your 5-lug rotor and compare it to your orignal 4 lug rotor and tell me if the diameter and anything else is the same or different. Thanks in Advance Ted No problem Ted.....I can take pics of everything for you if you like. I know that Eric is the guru on this stuff....maybe what he has stated has helped. Ed |
jim_hoyland |
Apr 21 2011, 05:17 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Ed,
I can't think of the companies name. But they sell all kinds of performance brake parts. I bought rotors, pads, etc, and had them cross drill my rotors. Located on west side of Placentia Ave between 17th and 19th--can't miss it |
jim_hoyland |
Apr 21 2011, 08:06 PM
OK - just remembered. It's Porterfield.
They have a web page with all their product lines Good people, been in Costa Mesa forever |
Lo-Fi Version | Time is now: 10th June 2024 - 03:43 AM |
