Coil problem? sprung a leak!?, Suddenly running rough, bad idle, kills- |
DRPHIL914 |
Apr 21 2011, 07:10 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Anyone ever had a coil leak?
for the past 2 months car has run flawlessly, except for the clutch cable adjustment that had to be made last week, but 2 days ago, suddenly car started to miss, run really rough on the way home from work- was running fine in a.m. and leaving work, so i stop in parking lot at the hardware store. seemed to be electrical, nothing obvious, but that night i figure either points or coil?? had a 69 austin healy that would act the same way, had a bad coil, - i pull the coil and it is sloshing- half empty of the insulating oil, apparently cracked and had been leaking out!! this coil was only 1 year old but NOT a bosch. Anyone ever heard of a coil doing that? put in a bosch coil- seems to run fine now! wierd! |
TheCabinetmaker |
Apr 21 2011, 07:20 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
In the old days it was not that uncommon. Haven't seen one leak in years. Maybe your car is telling you to keep bosch electrical parts in your ignition?
Drums66 |
Apr 21 2011, 11:22 AM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.....It happened to me once, back in......... (IMG:style_emoticons/default/poke.gif)
good you are up and running! (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:46 AM |
