Gluing body panels, Is this ridiculously stupid idea? |
mikea100 |
Apr 21 2011, 01:43 PM
Member Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
I recently caught “Speedmakers” on Speed channel. It showed Aston Martin factory and how they glue body panels, they went on to say that it creates stronger bond than welding. Has anybody tried gluing any panels. I was thinking about using some high strength epoxy and gluing Engman inner long kit, it seems as a good candidate as the pieces are flat and fit flush. What do you guys think?
r_towle |
Apr 21 2011, 02:00 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
read and learn all about the adhesives...
Its pretty common to use panel adhesive for non structural panels...most cars are made that way nowadays. For structural, I would not do it, but it might work with the right adhesive. Do some learning on 3M's website.... Rich |
sww914 |
Apr 21 2011, 02:22 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Have you ever seen a Ford taurus driving around with no quarter panels? They're all glued on, but in perfect conditions. You must duplicate those conditions and that epoxy has no strength with a large gap.
jim912928 |
Apr 21 2011, 02:43 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
this will be an interesting discussion. The body shop that did my 911 and 914 work (they turned my 911SC into a Widebody using Porsche metal parts and welded everything as the factory did) would like to use adhesives when I talked to them about putting the flares on my 914. He says it will be as strong or stronger then welding with no distorting of the metal from heat (he's used to adhesives as it's a corvette restoration shop).
02loftsmoor a 914 newbe |
Apr 21 2011, 02:50 PM
Newbie Group: Members Posts: 1 Joined: 21-April 11 From: Ft. Worth TX. Member No.: 12,967 Region Association: Southwest Region |
I work at Peterbilt. serveral truck models are glued together, two part glue that is very strong. holds up on a Class 8 truck
mikea100 |
Apr 21 2011, 03:12 PM
I followed Rich’s advise and did a quick research on 3M website. I think that if they glue box sides, van sides, utility vehicle sides, then it’s pretty safe to glue Engman inner long kit. I guess it’s not that ridiculously stupid after all and I’m going to give it a shot.
Benefits are huge: eliminates risk of shrinking/twisting longitudinals, damaging heater tube inside long channel, damaging wire harness, fuel lines and whatever else is inside tunnel, no need to take out entire interior etc. Another good candidate would be the battery tray. For those who are interested: 1) Alphabetical list of products http://www.3m.com/product/a_index.html 2) Adhesive, Automix Panel Bonding (pretty expensive) http://3mcollision.com/3m-automix-panel-bo...sive-08116.html |
r_towle |
Apr 21 2011, 03:24 PM
I would really like to hear how this works out.
I am not certain structural adhesive can stand up (thus why car makers still weld the unibody) For a fender...I agree it may be a better way to go versus welding. Rich |
jmill |
Apr 21 2011, 04:02 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
As far as glue joints go, it doesn't get any better than the Engman inner long kit. It's a lap joint with a huge amount of surface area. My main concern would be rust weakening the glue joint. If you paint it your joint will only be as strong as the paint to metal bond.
Strudelwagon |
Apr 21 2011, 04:33 PM
Member Group: Members Posts: 411 Joined: 11-October 08 From: interior, British Columbia Member No.: 9,633 Region Association: Canada |
As far as glue joints go, it doesn't get any better than the Engman inner long kit. It's a lap joint with a huge amount of surface area. My main concern would be rust weakening the glue joint. If you paint it your joint will only be as strong as the paint to metal bond. Mmmmmm Glue |
Bartlett 914 |
Apr 21 2011, 05:25 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
As far as glue joints go, it doesn't get any better than the Engman inner long kit. It's a lap joint with a huge amount of surface area. My main concern would be rust weakening the glue joint. If you paint it your joint will only be as strong as the paint to metal bond. But here is a big advantage. With a clean surface, the rust won't form because it will be sealed. When welding these panels, you should use a weld through primer to prevent rusting between the panels. As far as the Engman kit being glued in, it might be a great way to go. If the glue fails, your car won't fall apart. It is a stiffening kit and not really structural. |
mikea100 |
Apr 21 2011, 06:01 PM
Mark,
Great point. Check out this chart. Directions: http://www.3m.com.au/intl/au/auto_marine/a...g_Wallchart.pdf Basic summary: Surface needs to be stripped to bare metal. Thin layer needs to be applied to bare metal and will act as primer (9). Then 2nd layer needs to be applied. The more i read about it, the more I like it. You can even spot weld through this stuff (6), then you may use weld thru primer. |
sfrenck |
Apr 21 2011, 06:09 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
I followed Rich’s advise and did a quick research on 3M website. I think that if they glue box sides, van sides, utility vehicle sides, then it’s pretty safe to glue Engman inner long kit. I guess it’s not that ridiculously stupid after all and I’m going to give it a shot. Benefits are huge: eliminates risk of shrinking/twisting longitudinals, damaging heater tube inside long channel, damaging wire harness, fuel lines and whatever else is inside tunnel, no need to take out entire interior etc. Another good candidate would be the battery tray. For those who are interested: 1) Alphabetical list of products http://www.3m.com/product/a_index.html 2) Adhesive, Automix Panel Bonding (pretty expensive) http://3mcollision.com/3m-automix-panel-bo...sive-08116.html Don't forget this: 3m Adhesive Gun Wonder how much 200mL will cover? |
Bartlett 914 |
Apr 21 2011, 06:15 PM
For those who are interested: 1) Alphabetical list of products http://www.3m.com/product/a_index.html 2) Adhesive, Automix Panel Bonding (pretty expensive) http://3mcollision.com/3m-automix-panel-bo...sive-08116.html Don't forget this: 3m Adhesive Gun Wonder how much 200mL will cover? $411.00 for 6 200ml packs. Makes the Engman kit look cheap by comparison. I still think this is a cool method. You can even spot weld through it. |
Elliot Cannon |
Apr 21 2011, 06:30 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
THOMAS glued fiberglass flared fenders on his car. It worked great but he said you must make damn sure you have what you are gluing in the correct position because once the glue sets up it is ON THERE FOR GOOD. Having said that, I think I would rather weld the Engman kit on (which is what I did).
Cheers, Elliot |
mepstein |
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I think this was discussed before. I think the consensus was that gluing/bonding this piece is not the optimal way to secure since the two areas were not designed for epoxy bonding and the gaps in the panels will not be uniform. I think it would also be very hard to secure the reinforcement panel to the long and especially to the firewall while the glue dries.
Elliot Cannon |
Apr 21 2011, 06:36 PM
(IMG:style_emoticons/default/agree.gif) What he said.
surfbus66 |
Apr 21 2011, 06:41 PM
Newbie Group: Members Posts: 33 Joined: 13-February 09 From: Clinton/Akron,Ohio Member No.: 10,048 Region Association: None |
I bought a product called Fusor made by Lord Industries. I used it on my bus when I replaced the long rocker panel on the left side. I was affraid of having major warping welding on such a long peice. Worked great! However, it needs to be clamped tight for it to hold. I glued two 1" strips together and could not tear them apart.
jmill |
Apr 21 2011, 06:52 PM
You can vacuum bag it easy. I've vacuum bagged heater blankets onto airplane wings. Get some vacuum tape, thick plastic and a vacuum pump or the cheaper venturi vacuum generator. Way better than clamps and you'll have equal pressure on every square inch. It'll suck the metal down tight.
Attached image(s) |
sww914 |
Apr 21 2011, 06:53 PM
You can use 1/8" self tapping screws through both panels to bind them tight and then remove them later and glue the holes shut. Way faster and way cheaper than those silly Kleco fasteners.
raw1298 |
Apr 21 2011, 07:39 PM
Senior Member Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California |
I am using the 3m panel bond adhesive on my fiberglass quarter panels. I used the self tapping screws and filled holes with the adhesive when they were removed. The thread is here, I don't know how to attach it to this. It is titled "on the ground". I bought all mine on ebay for 40.00 per unit. I may be selling the applicator when I finish!
Lo-Fi Version | Time is now: 1st June 2024 - 10:54 PM |
