ignition switch - how do i install it? |
tod914 |
Apr 15 2003, 10:18 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
my 75 2.0 ign switch is on the way out - new 1 comming wed. how do i install it? didnt see any tech arts on it.
Thanks! |
Chris H. |
Apr 15 2003, 10:34 AM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
I think I have some directions, but essentially you have to take the steering wheel off, unscrew the wipers and turns (I think), then there will be a single bolt holding the switch in. Unbolt that, and if you are just swapping out the white part that is behind the key I think you slide that out the back, slide the new one in, put it all back together and you're done. I just swapped the entire cylinder, key and all, with another one, so I'm not positive how to get the white portion out....
DON"T FORGET TO MARK THE STEERING WHEEL POSITION!!! Otherwise it's a bitch to get lined back up. |
Lo-Fi Version | Time is now: 11th June 2024 - 12:19 PM |
