ring & pinion mesh, is this right? |
Chris914n6 |
May 22 2004, 01:00 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
inside high, outside low.
At .2mm spacer gap. Attached image(s) |
Chris914n6 |
May 22 2004, 01:01 PM
asfd
Attached image(s) |
KenH |
May 22 2004, 08:27 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
Ideally the it should show contact in the middle section of the teeth.
I would try to move it a bit closer. Do not forget to check the Diff. Cover pre-load dimension. Ken |
Lo-Fi Version | Time is now: 1st June 2024 - 03:44 AM |
