| Niklas |
May 4 2011, 12:26 PM
Porsche 914 Sweden ![]() ![]() Group: Members Posts: 369 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
Hello!
Anyone got pictures of hood pins on there cars? Niklas |
| mepstein |
May 4 2011, 12:54 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,982 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Do a search for "Porsche 914-6 GT" with the quotes. Many of them have hood pins.
| pjhaun |
May 4 2011, 01:05 PM
Member ![]() ![]() Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
I put the hood pins and fuel door on this winter. ![]() |
| dflesburg |
May 4 2011, 01:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
Yup.
| pcar916 |
May 4 2011, 01:36 PM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
Here be mine...
![]() Haven't needed the front two even at Texas Motor Speedway or Mid Ohio... or on the road either. Good luck |
| MrHyde |
May 4 2011, 04:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
Sorry to hijack, but why do some people have 4 hood pins ? Shouldn't 2 be enough ??? or are you not using the factory latch at all ??
| pcar916 |
May 4 2011, 04:39 PM
Shouldn't 2 be enough ??? or are you not using the factory latch at all ?? Not a hijack and I've found two to be enough without the factory latch. But I'm using a steel hood. With a fiberglass (and perhaps CF) hood I would definitely use four. In the latter case it might be overkill but over many years I like to over-engineer against vibration damage in rigid materials. The factory latch would be redundant in those cases as well except that a street car may need an inside lock for security. Gussets are good. |
| Chris Pincetich |
May 4 2011, 06:24 PM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Mine has 4 pins (carbon fiber hood) because that's what the factory 914 GT had!
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) |
| Bills914-4 |
May 4 2011, 06:26 PM
Member ![]() ![]() Group: Members Posts: 313 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
Thanks for pics & the thread (IMG:style_emoticons/default/biggrin.gif) , I was thinking just to 2 pins plus the latch ?
Now you got me thinking 4 pins , Bill D. |
| campbellcj |
May 4 2011, 10:48 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,723 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
I did the 4 pins GT-style with the thin Getty lid and no stock latch. With the steel lid I used 2 pins plus the stock latch.
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-21-1304570933.1.jpg) 914R at Pomona by cjcam, on Flickr |
| VaccaRabite |
May 5 2011, 11:38 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,936 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I am using 2 pins on a steel hood and no latch.
| Niklas |
May 5 2011, 03:06 PM
Anyone that have closeup pictures?
I also want to look inside the hood. Niklas |
| jt914-6 |
May 5 2011, 03:37 PM
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Here's how mine is....hope this helps some....steel hood, factory catch, hood pins....street/track car...I need to lock the front when needed....
| campbellcj |
May 5 2011, 03:39 PM
Anyone that have closeup pictures? I also want to look inside the hood. Niklas This may help. For the outer/rear one, the pin can go directly in the location where the rubber stop normally resides. For the inner/front one, I fabricated a simple aluminum bracket and riveted it in place. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm4.static.flickr.com-21-1304631544.1.jpg) 914R hood pins and brackets by cjcam, on Flickr Cheers, |
| Elliot Cannon |
May 5 2011, 06:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Fiberglass hood, no factory latch, two pins.
| Eric_Shea |
May 5 2011, 11:18 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
(IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-a.akamaihd.net-1110-1304659091.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-a.akamaihd.net-1110-1304659092.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-a.akamaihd.net-1110-1304659092.3.jpg) |
| Niklas |
May 6 2011, 01:21 AM
Hello!
Thank you everbody. Perfect pictures. Niklas |
Lo-Fi Version | Time is now: 6th November 2026 - 02:26 PM |
