1.7 to 2.0 conversion, fuel injection compatability |
john d. collard 914 |
May 10 2011, 01:19 PM
Newbie Group: Members Posts: 1 Joined: 7-May 11 From: carmel valley ca. Member No.: 13,038 Region Association: None |
I am putting a 1976 2.0 into my 1973 1.7. The manual says there is only slight modifictions to the D-jetrronic system, can I use my 1.7 ECU with the 2.0 motor with 2.0 injectors? I do not have the 2.0 ECU.
SirAndy |
May 10 2011, 01:52 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I am putting a 1976 2.0 into my 1973 1.7. The manual says there is only slight modifictions to the D-jetrronic system, can I use my 1.7 ECU with the 2.0 motor with 2.0 injectors? I do not have the 2.0 ECU. I'm pretty sure it will fire up and run, but how good is anyone's guess. (IMG:style_emoticons/default/confused24.gif) I used a 1.7L D-Jet system on a 1.8L motor and it ran just fine. (IMG:style_emoticons/default/popcorn[1].gif) PS: (IMG:style_emoticons/default/welcome.png) |
poorsche914 |
May 10 2011, 02:08 PM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Drums66 |
May 10 2011, 02:55 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
......I'd say it's doable......with a hiccup or 2 (IMG:style_emoticons/default/flag.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
JeffBowlsby |
May 10 2011, 03:17 PM
914 Wiring Harnesses Group: Members Posts: 8,526 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The 73 1.7L ECU was the same as used on the 73 2.0L, that and the 2.0L injectors should be fine.
But the rest of your 1.7L system will not be sufficient. Are you going to use the 76 2.0L intake system? Which FI harness? Which MPS? Which sensors? Use Brad Anders webpage to review teh parts you'll need. |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:11 AM |
