front geometry help, how much camber adj? |
mskala |
Apr 17 2003, 07:58 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Okay suspension gurus,
What's the deal with the front camber? How much adjustment is there supposed to be? People aim for -1.5 degrees so I was kinda assuming that the range would be about that much. But of course when I borrowed a bubble gauge, I'm not able to change things by more than 0.75. When I do the rough math, with the strut somewhere around 25" long, the adjustment slot about 0.77", and the bolt diameter of 0.39", that leaves arcsin((0.77-0.39)/25)=0.87 degrees. What am I missing? Want to get real camber in front, but stay in stock class. Thanks, Mark S.(IMG:http://members.rennlist.com/marks/build.gif) '70 914-6 |
drew365 |
Apr 17 2003, 09:16 AM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
The guru's are still sleeping so I'll pass along my experience. The first time we aligned my car he was only able to get about .75 negative camber up front. The next time we installed the Weltmeister camber plates and hacked the opening some and got -2.0. I don't know what you could expect from using the camber plates without widening the opening since we didn't do that. Hope this helps some.
Brad Roberts |
Apr 17 2003, 09:27 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
You have to cut the tub. If you dont buy the upper monoball strut holder... you have to trim your OE rubber strut holder. There is not enough room in the tub for the strut holder to "move over" towards the tank without cutting it down on the side that hits.
Finding extra strut holders is easy (around my place) because we replace them frequently. I can show you where to cut yours. The tub: normally requires using a small die grinder and opening up the holes for the 3 bolts (so they can now move over farther) B |
crash914 |
Apr 17 2003, 10:00 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/cool.gif) Mark, let me know what you find out...I might do the same. My tires rub now at extreme cornering.......I don't know why you are worried about staying in stock class, you are the only one there anyway........ (IMG:style_emoticons/default/beer.gif)
herb |
mskala |
Apr 17 2003, 12:22 PM
QUOTE(crash914 @ Apr 17 2003, 11:00 AM) ...I don't know why you are worried about staying in stock class, you are the only one there anyway........ Cause FTOD is more impressive from class 6 than 14 (IMG:http://members.rennlist.com/marks/vsmilie.gif) I'm not opposed to camber plates because things can be put back. I'm not cutting up a good condition -6. Mark S. '70 914-6 |
mskala |
Apr 17 2003, 12:25 PM
Thanks everyone. Just needed to be sure I wasn't missing anything. I've
only got about -0.75 on the fronts, and don't think I can go to any lower height. Mark S. '70 914-6 |
J P Stein |
Apr 17 2003, 01:47 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
These will give a bit over 1 deg more negative camber. You'll then prolly have to pitch your strut dust covers.
Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:32 PM |
