Advice needed: Dropped the engine...and found... |
PBC914 |
May 28 2011, 03:16 PM
Member Group: Members Posts: 192 Joined: 30-December 10 From: Minneapolis Member No.: 12,545 Region Association: Upper MidWest |
...a broken upper case! This is the first time I've had time to drop the engine and do some major work on the engine itself. I bought it this winter and was not able to view the engine closely because of all of the debris on it. It was not running at the time. It looks like the cylinder broke on top, and broker the case on the passenger side on top. I found a rusty connecting rod piece. Major bummer.
Question-is the case repairable? I want to keep the car original with the original engine. Any suggestions are greatly appreciated. |
john rogers |
May 28 2011, 03:59 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Cases are generally not repairable and if the rod has rust the other parts inside are toast so get another engine and in your spare time strip this one for things like heads, etc.
70_914 |
May 28 2011, 04:38 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
Take it to an aluminum welder and ask, don't take the opinions of people online who can't even see the engine...
Elliot Cannon |
May 28 2011, 04:44 PM
Take it to an aluminum welder and ask, don't take the opinions of people online who can't even see the engine... Unless, of course, those opinions are based on years of experience. I think he said "generally" not fixable. There are exceptions. (IMG:style_emoticons/default/smile.gif) |
TheCabinetmaker |
May 28 2011, 05:35 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Damn.thats kinda harsh Kevin. most of the threads here are asking the opinions of others. Most of which are valued opinions. Not listening to advice of the people who know is usually a recipe for disaster. Ask all you want man.
stewteral |
May 28 2011, 06:44 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Take it to an aluminum welder and ask, don't take the opinions of people online who can't even see the engine... Another Opinion: The "weldability" of the cases is dependent on the Aluminum alloy and the Germans do LOVE mixing Magnesium into their aluminum. I do NOT know what the alloy is, but know it could very problomatic welding. The best thing is to call a weld shop and ask them about their experience trying to save cases. The point that no one has mentioned: IF a case CAN be welded, there is NO doubt that any matting surfaces will have to be re-machined. It the break is around the bores, it may work OK. However, if the break involves the case mating surface to the other case half, the surface must be milled and THEN the cases, bolted together, will HAVE to be line-bored for bearing fit. The last question: What forces created the break in the case? Will you feel SURE that a weld repair will recreate the strength of the original casting? Lots of unknowns here! If it were MY engine, I'd find another engine and rebuild it...or....At the very least a replacement case and extensive rebuild ot the internals. A last (and probably distasteful choice to most 914ers) would be to go Straight VW, dump the EXPENSIVE Type IV engine and enjoy the volume pricing of building a 2200 cc Type II or type I engine. The parts are EVERYWHERE and they are cheap relative to 411!. I'm currently doing a complete bare-chassis restoration of a '73 and ended up putting $1000 in the engine rebuild. I must admit that the cost included being raped by AutoAtlanta on main bearing: $200, a Weber carb setup for $250 (used) and extra cost for BIG Bores (1.7l goes to 1.9l). BTW: I've been rebuilding street and race engines for 49 years) Hope this helps, but the decision is YOURS, Terry |
Richard Casto |
May 28 2011, 06:52 PM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
One of my previous 914s had a case that had been repaired via welding. I can't give you details of how as it was done by a PO.
Richard |
Jacob |
May 28 2011, 07:03 PM
Member Group: Members Posts: 131 Joined: 12-February 08 From: Mansfield, Oh Member No.: 8,705 Region Association: Upper MidWest |
I am not an expert in these matters myself, but in the book "How To Rebuild Your Volkswagen Air-cooled Engine" by Tom Wilson. From HP Books. Printed 1987. On page 77. In the caption under a severely cracked aluminum case, it says :
"Aluminum Type 4 cases can be welded, welded again, and welded some more. Good thing too." The opinion, of the author, of the book, was that the type 4 was the most desired of the VW air-cooled engines. He preferred the aluminum case over the magnesium cases of the previous engines. Book is available on Amazon for $15. I thought it was very informative. http://www.amazon.com/Rebuild-Volkswagen-a...s/dp/0895862255 |
Mike Bellis |
May 28 2011, 07:05 PM
The problem is getting the case clean enough to weld. If you do have a magnesium case, try welding it outside. Once you spark mag it will burn and burn and burn and burn....
Unless your car will be restored to factory apperance, there is not a ton of value in the original engine. You may spend a lot of money you don't need to. Weigh the cost versus the value at resale. Even if you save it, the engine is "repaired" and you will loose some value. |
stugray |
May 28 2011, 07:08 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I was a welder for 13 years.
I DO NOT recommend trying to fix a type IV engine case with welding. the ONLY exception would be if this was a very valuable engine/chassis mix that just cannot be split up due to originality. Otherwise, you will spend ~1/10 of the cost replacing it vs fixing it and then you will never be able to depend on the reliability. Just my 0.02... Stu |
Derek Seymour |
May 28 2011, 07:17 PM
Member Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California |
Buy another engine, drop it in, enjoy your 914. Keep the original and take the proper time to repair it. Type IV's are robust, they can take it, a Type I can't. However you need to do it right the first time. You will spend similar amounts of $$$ repairing a rush job on your current engine as buying a well built running Type IV. IMHO
PBC914 |
May 28 2011, 09:09 PM
Thanks everyone-I'll give the weld a try first. Keep the suggestions coming, I very much appreciate everyone's time, experience and input.
Paul |
speed metal army |
May 28 2011, 09:23 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Hey,any welder experienced in alloys will have no problem making the repair.Choose wisely.I have personally repaired some"unweldable" or "not salvageable" items.All of which are still ticking away to this day.
Dont believe the hype. |
McMark |
May 29 2011, 12:46 AM
The only question worth considering is how much money is the originality worth to you? As far as I've seen 914-4 buyers never seem to care about numbers matching, and I would expect more people to have doubts about a welded case. Other than for a competitive concours car, I simply don't see the value in it.
But that being said, it's your car and your money, so follow your dreams. (IMG:style_emoticons/default/wink.gif) |
stugray |
May 29 2011, 02:40 PM
For the cost of welding, machining the mating halves , then align-boring, you could have another complete running engine.
AND you have not found the root cause for the initial failure.... I guarantee that more problems will be found once you crack it open. Dont believe the statement "Dont believe the hype." The TRUTH is that: it would cost more to fix that than to replace it. Stu |
speed metal army |
May 29 2011, 04:48 PM
For the cost of welding, machining the mating halves , then align-boring, you could have another complete running engine. AND you have not found the root cause for the initial failure.... I guarantee that more problems will be found once you crack it open. Dont believe the statement "Dont believe the hype." The TRUTH is that: it would cost more to fix that than to replace it. Stu (IMG:style_emoticons/default/rolleyes.gif) ..The "dont beleive the hype" statement was referring only to the weldability of the case.Nothing more.And the "choose wisely" statement was referring to choosing a welder that knows his stuff. (IMG:style_emoticons/default/welder.gif) |
r_towle |
May 29 2011, 08:29 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
It can be welded....its been done for years when the lower oil sump pick up tube mount is broken off, or when its stroked out to a very large stroke.
Take it to a pro and listen to the advice of a good welder that is looking at the part in person. RIch |
Bleyseng |
May 30 2011, 09:30 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
it can be welded but you won't be saving time nor money in the long run. Find a new case and built the engine with that. (IMG:style_emoticons/default/piratenanner.gif)
IronHillRestorations |
May 30 2011, 12:37 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
New cases are fairly cheap compared to what you could get into trying to save one that had that level of failure.
There's usually much more than what meets the eye, but that's just my opinion based on the limited facts. |
70_914 |
May 30 2011, 09:18 PM
Take it to a pro and listen to the advice of a good welder that is looking at the part in person. RIch Careful! I was attacked for making the same suggestion... overly harsh, apparently. (IMG:style_emoticons/default/icon_bump.gif) We need pictures! |
Lo-Fi Version | Time is now: 1st June 2024 - 02:29 PM |
