Brake problems |
Brake problems |
duane-9146 |
Jun 6 2004, 01:59 PM
Vegas Duane Group: Members Posts: 4 Joined: 6-June 04 From: Las Vegas Member No.: 2,161 Region Association: Southwest Region |
I replaced my front calipers and my master cylinder, both with re-built parts, after rebuilding my front suspension. I have bled at least a quart of fluid through the system and cannot get the pedal to firm up more than a couple of inches off the floor. Shaft clearance into the cylinder looks good. I can't see any leaks. I'm stumped. Any clues other then a bad master cylinder?
TheCabinetmaker |
Jun 6 2004, 02:06 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Did you bleed the master cylinder?
Oh, welcome to the club. Got a pic of your car? is it an original six or a conversion? |
tat2dphreak |
Jun 6 2004, 03:22 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
bleed the prop. valve? that little bastard is the source of a lot of frustration...
welcome to the club! |
Eric_Shea |
Jun 6 2004, 03:55 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/agree.gif) Bleed the proportioning valve or...there's a two man procedure that involves "heavy" pedal pressure. You really have to slam it to get the prop. valve free of air.
Does it get better by pumping the brakes? Have you set your emergency brake clearances yet? Welcome to the club! (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 5th June 2024 - 10:57 AM |
